38 gallon tank install in a 92-96 (97HD) - Page 6 - Ford Truck Enthusiasts Forums
  #76
Old 08-04-2014, 05:32 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Originally Posted by OlePOS#17 View Post
Bob,
Great write up!
My '92 is a cab chassis with a utility bed. Does that mean this tank would not fit between the rails? Would a 35 Gal Bronco tank fit?
Also a note some of your pics are no longer showing.
Thanks
Correct, the F26D tank does NOT fit in a cab-n-chassis truck. I don't think a Bronco tank will either. I would be looking at a tank from a 99+ SuperDuty cab-n-chassis
  #77
Old 08-04-2014, 06:58 AM
David7.3's Avatar
David7.3 David7.3 is offline
Where is the beer?
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
Exhaust
Quote:
Originally Posted by Fastback460 View Post
I'm was really considering doing this, it's a great idea and this write up makes it look pretty simple.
But then I looked under my truck today, and realized that my exhaust is only about 3 inches from the bottom of the tank .
I don't really want to cut up the exhaust and lower it, so I may be going with the regular 19 gallon after all.
If your exhaust is in the factory spot the tank will fit, the tank kinda tapers down as it goes past the frame. I think they do that for the exhaust and hitches
  #78
Old 08-04-2014, 10:24 AM
OlePOS#17 OlePOS#17 is offline
OlePOS#17 is starting off with a positive reputation.
Quote:
Quote:
Originally Posted by Bob Gervais View Post
Bronco tank is 32 gallon, which is also a hell of a lot better than a 19 gallon. The Bronco tank is smaller in width and length, but is deeper than the 38 gallon tank.
I guess I'm going to have to crawl under there measure the dimensions of my existing tank.
Was the 35 gal the only option offered in the Bronco?
Where did Ford source their tanks from for the longer cab chassis?
Are the frame widths the same on all the Superdutys ?
I wonder what other differences I'll find.
  #79
Old 08-04-2014, 09:06 PM
Bob Gervais's Avatar
Bob Gervais Bob Gervais is offline
Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.
I can't answer any of your other questions, but the 32 gallon tank was the only one offered for the Bronco.
According to info on Rock Auto, the Bronco tank is 31 7/8" wide x 22 1/4" long x 15 3/4" deep.
I'm sure Brad will know for sure, but I think pickup frames are 34" wide, and cab/chassis are 32" wide. If that's true, the Bronco tank should fit your cab/chassis. If you end up going the Bronco route, you'll need a sending unit from a Bronco as well.
  #80
Old 08-04-2014, 09:22 PM
Cab-n-chassis frame width is 34"(outside)
Pickup and bronco frame width is 36"(outside)
Cab-n-chassis used the same front tank as pickups. Rear tanks was narrower to fit narrower frame but deeper(also no spare tire to worry about)
Superdutys(99+) have 2 different frame width just like OBSs(34" and 36")
  #81
Old 09-19-2014, 11:02 AM
Mikemusial Mikemusial is offline
Mikemusial is starting off with a positive reputation.
Does anyone have a part number for a diesel fuel pick up and fuel sender for the 38 gallon tank?
  #82
Old 09-19-2014, 12:17 PM
Quote:
You have to make your work if it did not come with the new tank(Lengthen the pickup tube and bend the float arm)
  #83
Old 09-19-2014, 01:12 PM
So basicly a trial and error to get it right? It is there some method of madness to this float arm bending?
  #84
Old 09-19-2014, 03:45 PM
88dually 88dually is offline
88dually is gaining momentum as a positive member of FTE.
When i bought my 38 it came with extentions for sending unit an wires, but mine is a gasser. I dont know what deisel sender looks like.
  #85
Old 09-19-2014, 05:09 PM
Quote:
Same thing but no fuel pump
  #86
Old 09-19-2014, 08:43 PM
But what about the fuel sender? The gauge won't be accurate with the current location. Won't it read empty but still have a few gallons left?? The float won't drop far enough. Or am I overthinking this.......
  #87
Old 09-20-2014, 08:21 AM
Let me post it again since you missed in the first time
  #88
Old 09-20-2014, 08:25 AM
Ok got it. So I'm just over thinking it.
  #89
Old 02-03-2015, 09:37 PM
WickdL WickdL is offline
WickdL is starting off with a positive reputation.
I know this has been said but, thanks Bob!
I just did this swap with your parts list to my 97 F250 4x4. My only difference was mine had a skid plate for the lower mounting instead of straps. Extentions that came with tank worked fine. I had to trim the back of the skid plates around my Mag-Hytec differential cover.
Tony B.
  #90
Old 02-03-2015, 10:22 PM
ponykilr's Avatar
ponykilr ponykilr is offline
ponykilr has a good reputation on FTE.ponykilr has a good reputation on FTE.
So if you pull a 92-96 Bronco tank with fuel pump module and all intact, will it bolt into a 96 pickup? Just plug and play?
Volt Meter instig8r63 1967 - 1972 F-100 & Larger F-Series Trucks 30 03-14-2016 07:52 AM
1995 F150 Centurion CC build thread... Bob Gervais 1987 - 1996 F150 & Larger F-Series Trucks 49 01-29-2016 07:18 AM
New member with a new truck Htchevyii 1957 - 1960 F100 & Larger F-Series Trucks 8 12-01-2014 11:48 PM
Carburetor issue 78 & 87 Super Cab 1957 - 1960 F100 & Larger F-Series Trucks 12 08-20-2014 02:23 PM
Bought a Centurion! Bob Gervais 1987 - 1996 F150 & Larger F-Series Trucks 31 01-25-2011 11:17 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
