38 gallon tank install in a 92-96 (97HD) - Page 2 - Ford Truck Enthusiasts Forums
Old 05-01-2013, 08:32 PM
Bob Gervais's Avatar
Bob Gervais Bob Gervais is offline
Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.
Well that sucks. I did a three inch single system on mine, with an offset/offset muffler. The tailpipe is about an inch away from the tank, so I may change the muffler to a center/center. The current muffler is too quiet anyway.
Old 05-02-2013, 10:41 AM
Original post edited to add pictures and explanation of ground wire for the fuel level sensor.
Old 05-02-2013, 04:12 PM
Fastback460's Avatar
Fastback460 Fastback460 is online now
Fastback460 is a splendid one to beholdFastback460 is a splendid one to beholdFastback460 is a splendid one to beholdFastback460 is a splendid one to beholdFastback460 is a splendid one to beholdFastback460 is a splendid one to behold
Quote:
Mine is 3 inch true-dual with series 10 flowmasters(nice and loud). It is a custom made exhaust that was on the truck when I got it. It ends right behind each rear tire(you can see it in my sig photo). But when it goes over the axle, it comes back down right under each front corner of the rear tank, so it doesn't leave any room for a bigger tank, or even my full size spare
Old 05-02-2013, 07:00 PM
Gotta say, I like how they did the tailpipe exits. Seems like all of the less expensive exhaust kits exit under the rear bumper.
Maybe the pipes could be tweaked a bit?
Old 05-02-2013, 09:06 PM
I think they are about 12 inch tips welded on the exits. Probably one of my favorite things about my truck is the exhaust, I have never heard anything else like it.
When I bought the truck the PO said he got it done from stock for about $400. That included cats, mufflers, and the dual pipes. I was surprised, I thought for sure a setup like this would be a bit more $$$
I could try to see if the brackets holding up the exhaust could be adjusted lower without actually cutting pipes. I'll get under there again tomorrow and see If there is enough room to work with before I rule out this tank for sure.
Old 05-02-2013, 09:38 PM
craftsmangary's Avatar
craftsmangary craftsmangary is offline
craftsmangary is starting off with a positive reputation.
Nice write up. I have done this upgrade on my truck and sure is nice for traveling.
Old 05-03-2013, 04:34 PM
Thanks! And I agree, this will be great for road trips.
Old 06-19-2013, 11:11 AM
Wolfknyte's Avatar
Wolfknyte Wolfknyte is offline
Wolfknyte is starting off with a positive reputation.
Awesome, I was just coming on here to search about being able to use the high capacity tank on the '93 flare side I just picked up this weekend.
Excellent write up, thanks!
Old 06-19-2013, 12:46 PM
I'm glad you replied, I forgot to update this. I found an additional issue with extending the lines, and a quick fix.
I didn't realize that the hanger tubes have a bracket that screws to the fuel pump module, to prevent it from sliding off the tubes. I found out the hard way, my fpm slipped off the tubes, causing a no start/very low fuel pressure issue.
I made a bracket (really just a piece of stainless sheetmetal) that bolts to the original hanger tube bracket, and screws to the plastic fpm.
No problems since, and the Walbro pump is doing just fine.
Old 06-19-2013, 01:17 PM
xmontex4's Avatar
xmontex4 xmontex4 is online now
xmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to all
Nice! I really need a bigger tank in my truck I'm always filling it every few days with all the traveling i have been doing for work and this would make it so much nicer! not to mention that my gad gauge is wrong. do you have to modify the fuel pump or is there one that can be purchased for the 38 gallon tank?I think mine is on its way out anyway so i would rather just replace it.
Old 06-19-2013, 03:18 PM
warren561 warren561 is offline
warren561 is starting off with a positive reputation.
Thanks for sharing the pics for this project Bob Gervais!
You don't need this unless your uppper straps are rusted out, right? The 38 gallon upper straps aren't any different than the existing straps (used for the 18 gal rear tank)?
-3/8 stainless tube, McMaster-Carr part# 89785K238
-5/16 stainless tube, McMaster-Carr part# 89785K229
-(2) 3/8 stainless unions, McMaster-Carr part# 5182K345
-5/16 stainless union, McMaster-Carr part# 8239K194
These are only needed since you're re-using your existing pump, hanger, and sender unit, right?
If my pump and sending unit is dead, I should probably just get a Bronco hanger. It looks like Motorcraft PFB4 includes the pump and hanger. The sender is Motorcraft PS22.
EDIT-
The Motorcraft part numbers I referenced above is NOT for the 38 gallon tank. They are for the 33 gallon Bronco tank (Spectra F).
Old 06-19-2013, 04:48 PM
Correct on the upper tank straps. Mine were a little rusty, and I had the bed off so I figured why not.
The bronco hanger may or may not work in this application. I think the Bronco tank is deeper than this 38 gallon tank. I had a used Bronco hanger to work with, but it didn't appear as though I could cut the required amount out of it to be able to use it.
  #28
Old 06-19-2013, 04:50 PM
Quote:
The only modifications are as shown with the tubing on the hanger. The fuel pump is encased in the white plastic can, which I had called the fuel pump module. I'm sure there's a name for it, but that's what I called it.
As far as I know, there's no "drop in" replacement pump/hanger assembly that exists for using a 38 gallon tank in our body style.
  #29
Old 06-19-2013, 08:25 PM
You're right. My bad. I thought that the 38 gallon tank was the Bronco tank. It is not. It's an "optional" tank for the 85/86 F-series.
I wonder if the 33 gallon Bronco tank (Spectra F) will fit in our generation of trucks? That would enable us a drop-in hanger, pump, sender assembly.
  #30
Old 06-21-2013, 03:54 AM
kermmydog's Avatar
kermmydog kermmydog is offline
kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.
Great Write Up Bob. With dual tanks changing the rear tank to a 38 gallon would give me 57 gallons total. At 17-19 mpg on the road that is a 1000 miles non stop for gas. Have to put a pisser in the cab I guess.
Thanks again Bob great write up.
Craig
Volt Meter instig8r63 1967 - 1972 F-100 & Larger F-Series Trucks 30 03-14-2016 07:52 AM
1995 F150 Centurion CC build thread... Bob Gervais 1987 - 1996 F150 & Larger F-Series Trucks 49 01-29-2016 07:18 AM
New member with a new truck Htchevyii 1957 - 1960 F100 & Larger F-Series Trucks 8 12-01-2014 11:48 PM
Carburetor issue 78 & 87 Super Cab 1957 - 1960 F100 & Larger F-Series Trucks 12 08-20-2014 02:23 PM
Bought a Centurion! Bob Gervais 1987 - 1996 F150 & Larger F-Series Trucks 31 01-25-2011 11:17 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
