1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
growling noise
Old 04-26-2013, 08:40 PM
brianjordanf250's Avatar
brianjordanf250
brianjordanf250 is offline
growling noise
I have an 06 f250 that is making a growling noise that is speed sensitive and sounds like it might be coming from the front. I thought it was tire noise from my old worn out tires but with new tires it still maks noise, but tires have pretty rough tread. How can I tell if it could be a wheel bearing? It seems like the noise quiets down a little on right turns. It is kind of a growling humming noise that changes with speed. Any ideas are appreciated. Thank you.
Old 04-26-2013, 10:19 PM
scraprat's Avatar
scraprat
scraprat is online now
Received 2,495 Likes on 1,304 Posts
It sounds like wheel bearings, jack a tire up in the air and spin it if you hear the noise there you go. Also grab it at the 9 & 3 o'clock position, push and pull see if you have play, you shouldn't, if it is the bearing don't let it go you'll end up paying more for spindle or hub.
Old 04-27-2013, 11:41 AM
V-10 duty's Avatar
V-10 duty
V-10 duty is offline
growl
jack it up and hold one of the coils on the spring or a leaf and spin the wheel if you feel the roughness its in the bearing and mostlikley the outer , its the load carrier. on a 4 wd carrier bearings also will make noise especialy at lower speed, 10-25 mph
Old 04-28-2013, 10:23 AM
brianjordanf250
Thanks for the replies, Ill jack it up and try that when it dries up outside.
derail01
02-02-2017 11:28 AM
fordguy4life
1997 - 2003 F150
05-08-2011 09:55 AM
butch h
Escape & Escape Hybrid
01-08-2010 10:15 AM
grizzly041771
1997 - 2003 F150
19
06-26-2008 08:48 PM
jvaski
1997 - 2003 F150
01-28-2007 12:36 AM
Quick Reply: growling noise
