long bed fuel tank in a shortbed truck?
So I have a long bed 1999 diesel truck I am selling that is pretty used up, so it will go for cheap, and my 2002 shortbed. I was thinking about swapping the tanks to get the larger tank in my shortbed, is this doable? I don't want to spend the money on an aftermarket tank.
edit, scratch the swaparoo used tanks are only $75 locally so What does it take to put a longbed tank in a shortbed crewcab truck?
ok I am confused, my E99 logbed supercabs tank is 60 inches long
my 2002 crewcab shortbed tank is 60 inches too?
the hanger straps are in the same locations relative to the front, rear leaf spring mount. it looks like the fuel pump outlets and hoses are in the same place relative to the rear spring mount. so the only thing I would have to do is use some extra radiator hose to extend to the filler?
But if the tanks are the same length where is the extra 10 gallons coming from?
The extra 10 gals may come from height or width, usually height if I remember correctly.
its height, the long bed filler hose would come out right at the rear cab mount. and the tank sits above the frame rail 1-2 inches, and there is no room for it at the cab. You would have to lower the tank a couple of inches to work and then still have to deal with the filler hoses.
Not worth it
Not worth it
