Vacuum Control for Distributor 1956 272 on F100
If the vacuum advance stayed active during wide open throttle, you would have too much advance at higher rpm. For pure performance, you don't need any vacuum advance.
With ported vacuum, you don't have any advance at wide open, either.
To boil it down, it ends up working very much the same but you have more advance at idle, it runs cooler, and is a little more torquey down low - all good things for a street vehicle.
To stay on subject, if Marty doesn't have "correct" ported vacuum available, manifold vacuum absolutely is an option.
I looked at the link for the modification to the Holley 94 to get the correct vacuum to an updated distributor. It looks pretty straight forward. I'll be looking into the possibility of getting a newer distributor but for now I'm pretty happy to have my truck working properly.
Thanks again for all the replies!
I have a 318” Y-Block with three Strombergs. Not being able to find a rare Stromberg with ported vacuum and not willing to drill holes in one of my original bases (I run the bigger 48 base in the center) I too run manifold vacuum. I should also mention I have a Ignitor III with multi-spark.
I did a lot of research on manifold vs ported vacuum advance. I came across many articles pro and con. Here is one that makes the most sense and is well written; Ported vs. Manifold Vacuum
I also agree with the part that the high dollar mechanical only distributors have no place on a street machine.
Please no snarky remarks because it is on a Chevelle Site.
Light Doug
11-19-2018 05:20 AM
Boostingaz
49
11-15-2017 11:52 AM
rashanny
08-14-2011 09:44 AM
Narwhal
11-26-2005 08:23 PM
