94 ford aerostar
94 ford aerostar
what would cause the front wheel on drivers side to lock up if it isnt the brakes. have been hearing a loud popping noise for a while on drivers side especially when turning left. today got really loud just driving and then a real loud grinding noise. then a loud pop and front wheel locked up and skidded across highway til i came to a stop. any idea what it could be or how can i at least get wheel to turn to get it on trailer
How long is "a while"?
Is this a 4wd van? If so, it's probably the CV joint.
Otherwise, it was probably the wheel bearing failing.
In either case, after making a lot of warning noises that were ignored, it failed catastrophically.
Should not ignore those noises, they only get worse.
Well that sounds suspect. A part that was recently replaced seemed to have failed.
At least one member of this forum has complained of how poorly made the aftermarket half shafts were, requiring multiple replacements.
All wheels have bearings; those for the 4wd are in the self-contained hub, while in the 2wd versions the brake rotor is part of the hub. I have seen bearings that got so badly blown out that they must have been making a racket that could not possibly be ignored, and their pieces welded themselves to the spindle. So yes, a blown wheel bearing can lock up the wheel. But I'm guessing your problem is caused by the CV joint failing. The tell-tale pounding noise on turns is an indication.
moron "mechanic" probably pounded out the old half shaft from the hub bearing with a sledge hammer instead of using a bearing/shaft puller, damages the bearing from impact force.
suggest a shop that specializes in front wheel drive half shaft replacement, the front end shops are good for this.
i suggest the Cardone New only Aero half shafts from rockauto.com. rebuilts aren't worth buying.
I've gotten more miles from the Cardones that the original Ford OEMs
mattri
13
01-15-2014 06:49 PM
england20
12-31-2010 11:58 AM
