1950 flathead - what to do while out of truck? - Ford Truck Enthusiasts Forums
Old 04-25-2013, 10:24 PM
Sherbo's Avatar
Sherbo Sherbo is offline
Sherbo is starting off with a positive reputation.
Hey all,
Have a 1950 flathead that I plan to drop in my 53 f100. I have no experience working on engines, but am trying to figure out what maintenance I should do while it is out of the truck.
Here is what I know:
  • engine is from a family friend, and was taken out not long after being rebuilt (truck it came from was junked). IIRC, it was rebuilt in the early 80s.
  • sat covered in a barn since
  • turns over
  • cylinder walls look good
  • a couple valves are sticking (have been spraying with penetrating oil and light weight oil)
I was thinking I'd take the oil pan off to clean out any sludge and just do a quick visual inspection.
What else should I do while it is out? I don't have the money to pay for a rebuild so want to know what I should do myself while it is out of the truck.
Thanks in advance!
Old 04-26-2013, 12:39 AM
fixnair's Avatar
fixnair fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
Yes, I would pull the pan and clean up the lower end. Look carefully for bearing debris. Hope you don't find any. Be careful working inside the pan. Most of those engines used leaded gasoline and the lead would settle in the bottom of the pan. Wear nitrile gloves and minimize your exposure.
Replace the pan using new gaskets and rope seals.
Next I would remove the heads and look closely for cracks around the valve seats. Wire brush around the valves and elsewhere in the combustion chamber to expose any cracks. If you can afford it take it to an engine shop that has experience with flatheads and have them inspect for cracks.
If it passes inspection look at the cylinder bores and pistons for excessive wear or scoring. Check for proper valve action too. Unstick any stuck valves too.
flathead and transmission questions farmall_7 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 10-15-2015 07:22 PM
Fan schroud problems jreilly57 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 01-10-2015 09:59 AM
Nice flathead! Chris 56 f6 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 03-06-2014 09:16 AM
Pipe running down from side of I6 226? Logistics Joe 1948 - 1956 F1, F100 & Larger F-Series Trucks 33 07-03-2012 10:50 PM
OVERDRIVE... can someone explain it to me? ricku 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 04-23-2012 10:36 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
