Traveling, spare parts?
Hey guys, so I wanted to come up with a list of parts that I or anyone traveling a lot, should keep in the truck. I have a 40 gallon plastic storage trunk I throw in the truck anytime I go on a trip and also during the winter.
Besides some recovery items and survival items. i.e. Tire chains, tow strap, schakles, etc. I would like to start a list of parts that should also be brought along. I would rather bust a few knuckles on the side of a road in a blizzard than pay/wait for a tow truck when I'm 500 miles from home.
Now, this list should exclude hand tools (unless specialty), socket sets, flashlights, recovery items, and survival. There are other list on FTE that are while compiled.
Here's the lists:
Spare Parts:
Tools:
Alright, see what else we can add.
Thanks guys
Here's the lists:
Spare Parts:
- Serpentine Belt
- Radiator hoses
- Large Hose clamps able to be cut to size
- Engine Oil
- Trans Fluid
- Steering Fluid
- Brake Fluid
- Coolant
- CPS if you have a 7.3L
- COP and boot for a V10
- Deferential Fluids
- Fuses (Including Mini/ATO/Maxi), Relays (Refer to user manual)
Tools:
- Permatek Gasket Maker
- Nuclear Grade Duct tape (Got it from work)
- Siphon Hand Pump
- JB WELD (Quick Weld)
- Air Compressor
- PB Blaster
- Electrical Tape
- Wire
- Multimeter
- Dielectric Grease
- Dynaplug Tire Repair
- Hose Splice/Repair Kit
- Safety Wire
- Tire Pressure Gauge
- HD Jumper Cables
- Tow strap
- Shackles
- Flares (LED)
- Tire Chains (w/ Snubbers)
- Shovel
Thanks guys
Dynaplug tire plugger, plus you should always have a multi-tool on ya' so that you can dig out whatever nail or screw gave you a flat. (Personally, I use Ride-On in all my tubeless tires, but I still carry a Dynaplug just in case I can help someone else.)
I stopped carrying a complete hose kit and just started carrying one of the splice-in kits instead. The hoses were just too bulky and frankly I've never had a hose leak since I started replacing them every five years with OEM parts.
I usually have a variety of zip ties since they weigh nothing and can come in handy. (Wish I knew how to safety wire better, as I'd have some stainless steel safety wire, too.)
I used to carry road flares, but I've recently switched to LED flares instead: Lite Flare is a compact electronic LED signaling device
I always have food and water (earthquake supplies), as well as emergency blankets, work gloves, and a ball cap.
Oh, and a tire pressure gauge since one isn't integrated into my compressor.
Sobiloff,
Get a set of these and the only time you have to do by hand is if you can't fit them in.
Here is a nice Youtube how to
Here is a page on how to safety wire
Safety Wire Techniques
being able to safety wire is very useful and once you know how.
You will find more good uses.
Sean
Sean
If you have a V10, an extra COP and boot. CPS if you have 7.3L. Dielectric grease.
Not sure if a multi-meter would be considered as a specialty hand tool. A spare battery for it if it is digital. Makes finding the blown fuse much easier.
Rain poncho/coat if it's pouring and you have a flat.
last trip that I have taken in my 99F250, my truck got some really bad gas in GA and NC (twice in 3 days). I had to replace fuel pump once in the parking lot, once building one out of two bad ones.
Now I do my research before I go on the trip to make sure either there is a store near by or I have enough tools and material to fix it on the spot
I would for sure get extra strainer for the pump and soldering kit.
Ya I hear ya with that....I was in Utah and no cell service where I was...I didnt even see another car/truck on the same road for a few hours of driving.
