2011 F250 GVWR v 2012 F250 GVWR - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-25-2013, 04:41 PM
Deejavue Deejavue is offline
Deejavue is starting off with a positive reputation.
Hi Everyone! I'm looking to buy a "new to me" F250, primary use will be to tow a fifth wheel. The configuration I'm most interested in is the extended cab, 4x2, 6.2L gas engine with the 6.5 ft bed.
However, all the specs I've found list the GVWR at 9,400 for the 2011 with a max payload of 3,020 versus the 2012 or 2013 trucks with a GVWR of 10,000 and a max payload of 3,800. Why the huge difference? And, if I do buy a 2011, can it be updated to the higher GVWR and payload? Or I'm I pretty much limited to the 9,400?
Thanks in advance for all your help!
Diane
Sacramento, CA
Old 04-25-2013, 09:06 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
The truck can be upgraded to handle the extra weight, but you'll still be legally limited to what the rating is on the Vehicle Certification Label on the door. I would be especially wary of exceeding that rating if I lived in California. The best advice would be to look for a 2012 or newer or expand your search to include an F350.
Old 04-25-2013, 10:09 PM
dualwheels66 dualwheels66 is offline
dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.dualwheels66 has a very good reputation on FTE.
Buy a F350
Old 04-26-2013, 05:47 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
The issue was when you bought your truck it was downgraded on the door cert only. Both are technically the same.
If you are buying a 5er I would go big with the F350 so you get the best door cert. Be sure to check it this time.
Old 04-26-2013, 09:54 PM
Thanks for the replies. I haven't bought a truck yet and will look at the F350 as well. Still odd the 2011 is rated 600 pounds less
Dee
Sacramento, CA
2017 - will a SRW finally be within limits for most 40' bunkhouse fifth wheels? 2009kr Fifth Wheel & Gooseneck RV Towing 19 05-19-2016 09:48 PM
I don't understand these ratings... FatOldGuy 6.7L Power Stroke Diesel 80 01-17-2016 04:44 PM
2011 F250 Towing question.. firebus 1999 to 2016 Super Duty 14 09-10-2014 11:11 AM
towing capacity of 2002 F@%) 7.3l mcguirehg Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 31 02-04-2014 07:36 PM
2012 F250 10k GVWR Horsepower? troverman 1999 to 2016 Super Duty 7 04-30-2013 09:46 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
