Block heater and hunting
Old 04-27-2013, 02:17 PM
tbugher62's Avatar
tbugher62
tbugher62 is offline
Hi Guys,My question when those of you hunters are out hunting how do you guys start your trucks when its REALLY cold out and you have no way of using your block heater?
Old 04-27-2013, 02:24 PM
FI460's Avatar
FI460
FI460 is offline
Truck should start down below freezing just fine when your batteries, glow plugs, and relay are in good shape.
Mine wouldn't start at all below 40*. Replaced my glowplugs and glow plug relay and I haven't encountered a temperature where it wouldn't start.
Old 04-27-2013, 03:01 PM
tbugher62's Avatar
tbugher62
FI460 ,Will your truck start on the first try during cold periods or does it take a few trys ?
I replaced my glow plugs and seals on my injectors,so I think I will go ahead and replace the relay also.
Old 04-27-2013, 03:09 PM
FI460's Avatar
FI460
FI460 is offline
Yes. I let the glow plugs work until they shut off. I can tell this because the voltage comes up considerably. On a real cold morning they might run for 2 minutes.
It's good practice to always check the glow plug relay when you're having cold start issues. Oftentimes people thing they have bad glow plugs when it's actually the relay. Cheap easy thing to change for starting insurance.
Old 04-27-2013, 03:22 PM
tbugher62's Avatar
tbugher62
Thank You thats what I needed to know.
RPM_Diesel
01-19-2014 08:54 AM
98rangerll
1999 to 2016 Super Duty
16
01-11-2014 02:08 PM
66shadow
10-14-2012 10:02 PM
BlueDiamond
15
01-08-2009 03:09 PM
David Matthews
19
01-17-2004 12:54 AM
Quick Reply: Block heater and hunting
