1 injector not spitting oil. CCT balance fault on that cylinder
Hello all, I ran a CCT test with AE because I thought it was running rough and got a cylinder #4 balance/ cylinder contribution fault. I have both valve covers off now and #4 is not spitting any oil. I just found the IDM pinout and will get the ohm #'s for all the injectors. Any ideas?
Ok, I'll do the swap next, Uvch looks and texts good. I ohm'd all the injectors at the IDM plug and they all said 3.0 Ohms.
on
1 Post
No, doesn't make a difference on the spacer under the coil. I had to ask that question myself a while back. I got the same code from a CCT with AE the other night. Same injector. Mine wasn't oiling like the others. They are premium built Rosewoods, just put in so I knew it wasn't the injector. Changed the harness for those two cylinders with another used harness, and it's oiling better and no codes on the CCT.
^ x2 I've been wondering about your miss, bill, as I suspect mine may be something similar, but I haven't dug into it yet. I did replace all my UVCH's when I did my GPs last time though and it didn't change anything. i'll have to remember the injector solenoid swap test if it comes to that...
modmxz
76
08-05-2013 08:55 PM
Mark Alligood
28
07-02-2012 10:31 PM
killthe6.0forddiesel
12-10-2011 05:36 PM
