1 injector not spitting oil. CCT balance fault on that cylinder - Ford Truck Enthusiasts Forums
Old 04-25-2013, 11:49 AM
brooksbronco17's Avatar
brooksbronco17 brooksbronco17 is offline
brooksbronco17 is starting off with a positive reputation.
Hello all, I ran a CCT test with AE because I thought it was running rough and got a cylinder #4 balance/ cylinder contribution fault. I have both valve covers off now and #4 is not spitting any oil. I just found the IDM pinout and will get the ohm #'s for all the injectors. Any ideas?
Old 04-25-2013, 12:01 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Check the UVCH to that injector and if that's good swap the solenoid with the one next to it and see if the issue follows the solenoid
Old 04-25-2013, 12:24 PM
Quote:
Ok, I'll do the swap next, Uvch looks and texts good. I ohm'd all the injectors at the IDM plug and they all said 3.0 Ohms.
Old 04-25-2013, 12:54 PM
i pulled 2 solenoids off and notice on the one that wasn't spitting oil that the spacer deal the solenoid sits on is turned 180 from where the other solenoid's is. Is that a problem?
Old 04-25-2013, 02:41 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
No, doesn't make a difference on the spacer under the coil. I had to ask that question myself a while back. I got the same code from a CCT with AE the other night. Same injector. Mine wasn't oiling like the others. They are premium built Rosewoods, just put in so I knew it wasn't the injector. Changed the harness for those two cylinders with another used harness, and it's oiling better and no codes on the CCT.
Old 04-25-2013, 03:15 PM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
So did that fix your miss again Bill?
Old 04-25-2013, 03:59 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
^ x2 I've been wondering about your miss, bill, as I suspect mine may be something similar, but I haven't dug into it yet. I did replace all my UVCH's when I did my GPs last time though and it didn't change anything. i'll have to remember the injector solenoid swap test if it comes to that...
Old 04-25-2013, 10:28 PM
ReBilld's Avatar
Quote:
Nope. I'll have all new Ford ones tomorrow. See what that does. I doubt that's my problem though.
Old 04-26-2013, 12:33 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Quote:
I thought you already changed the harness's Bill?
Old 04-26-2013, 03:33 AM
ReBilld's Avatar
Quote:
Two sets of Dormans. Just doing the Ford ones for piece of mind.
Fishbone help - engine knock cangim 1999 - 2003 7.3L Power Stroke Diesel 3 11-06-2016 06:23 AM
Engine firing order and cct and perdels. Fefanatic 1999 - 2003 7.3L Power Stroke Diesel 13 08-19-2016 07:48 PM
CCT Codes Please Help!!!!! akmikek 1999 - 2003 7.3L Power Stroke Diesel 15 04-09-2015 06:07 PM
CCT, CRV, and PERDEL explained. Tugly 1999 - 2003 7.3L Power Stroke Diesel 17 09-18-2014 03:27 PM
Pandora's Box Delvac1 1999 - 2003 7.3L Power Stroke Diesel 11 10-09-2008 10:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
