89 f150 spit and sputter and idle problem
when i bought the truck it had a small idle issue, now its spitting and sputtering when i get on the gas, its missing terribly just did a complete tune up, its started doin it right after it rained pretty heavy and has been acting wierd ever since. possible water in gas tank? im open to any suggestions. Thanks!!!!
for the idle problem its loping up and down up and down and then dies and my oil pressure gauge goes down and up only when im in drive when I put in park or neutral it idles fine, it only does it when I come to a stop in drive , as for the tune up I did plugs wires cap and rottor button all the wires are in the right spot cause I did em one by one and when I started it up it ran fine.
These next few things are on the assumption that it's fuel injected, since you didn't specify:
1) Check the idle air control (IAC) valve. With the engine running and up to normal operating temperature, unhook the wiring harness. If the engine starts sputtering and dying, it's good. Fuel Injection Technical Library » Idle Air Bypass (IAB)
2) Check the fuel pressure regulator. Simply pull off the vac line and if you smell gas or see it dripping out of the vac line, it's bad. Fuel Injection Technical Library » Fuel Pressure Regulator (FPR)
3) And, of course, check the trouble codes. Personally I'd just recommend buying a scanner b/c they're only about $30, but you can always do it the old fashioned way: Fuel Injection Technical Library » How To Run a Self-Test
Sorry about that, it is efi. thanks for the information, I was gonna put a new IAC on it tomorrow I took the one on there off it was a little gummed up.
Are you talking about the vac lines on the tank?? (havnt owned truck long still getting to know it)
and the truck is not OBD II where can I get the scanner, I read some where that it is a two prong plug and you complete the circuit a the check engine light flashes the code in short and long flashes
again thanks so much for your help
As for pulling the codes yourself, without a scanner- that's the link I provided you with in item #3.
If it's maintaining that pressure, you're fine. To confirm that, you'll want to ground the fuel pump pin on the diagnostics plug (see picture below) and run the pump for about 10 seconds. Then kill the pump and check the fuel pressure every 15 seconds for one minute. If it doesn't lose more than 5 PSI within 1 minute, it's good.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
03-08-2008 02:21 AM
jethrp007
12-12-2002 12:01 AM
