2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Power window out AGAIN
Old 05-04-2013, 07:33 PM
Kelly Aitken's Avatar
Kelly Aitken
Kelly Aitken is offline
I have a '08 Navigator. Had the driver side power window motor replaced a couple of years ago while it was still under warrenty. I was told then by a service tech that this is a very common problem. I have been out tof the country for about a year and a half now and my wife and son only drive it occationally. It is now out of warrenty and the window is messing up again. It goes up alittle bit and you have to keep hitting the switch untill it finally goes all the way up. I bet it doesn't have 10,000 miles on the truck since it was replaced last time. This is going to cost me this time. Anybody else have this issue? Is there a better fix? Thanks
Kelly
Old 05-06-2013, 02:37 PM
jimb726's Avatar
jimb726
jimb726 is offline
Kelly
Just for giggles, before you take it in, try spaying some silicone spay on the window tracks on each side of the window. Spray it liberally and then work the window up and down a few times. Sometimes the track gets crud in it. This may help. Lot cheaper than new regulator or motor.
Jeff heine
12-18-2016 04:42 PM
bigford8486
2004 - 2008 F150
11-04-2009 10:29 PM
tpd475
1997 - 2003 F150
09-13-2006 12:47 AM
kilika77
1997 - 2003 F150
11-12-2005 09:21 PM
markmacd
1997 - 2003 F150
12-31-2003 09:32 PM
Quick Reply: Power window out AGAIN
