4.9 Valve cover gasket.. help? - Ford Truck Enthusiasts Forums
Old 04-24-2013, 03:02 PM
Koch85F150's Avatar
Koch85F150 Koch85F150 is offline
Koch85F150 is starting off with a positive reputation.
I have an 1985 4.9 and need a new valve cover gasket what is the best to put on? also anything else i need to change when i replace it?
Old 04-24-2013, 06:01 PM
maverick600's Avatar
maverick600 maverick600 is offline
maverick600 is starting off with a positive reputation.
Quote:
Gives you the chance to inspect the valve train and make sure everything is wearing as it should. You can get a cork or rubber gasket. From what I have gathered everyone has their own choice but as long as you dont over tighten it then you should be fine either way. I am going with the cork on mine personally.
Old 04-24-2013, 11:01 PM
Yaga1973's Avatar
Yaga1973 Yaga1973 is offline
Elder User - What???
Yaga1973 is gaining momentum as a positive member of FTE.
I recently put a really nice Fel-Pro gasket on mine. It was so pretty and so well made it almost seemed a shame to install it.
Old 04-25-2013, 09:31 AM
Koch85F150's Avatar
Fel-pro cork is all I can get here where I work at. I think im going to give the cover a good cleaning and some paint while I have it off
Old 04-25-2013, 10:13 AM
Absolutely! Even gives you to straighten out and dents or bows it may have in it from previous people abusing or over tightening.
Old 04-25-2013, 10:56 AM
Koch85F150's Avatar
Quote:
to look at it you would think its never been taken off in the past but also 28 years is a long time lol
Old 04-25-2013, 11:51 AM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
The Fel-Pro rubber gasket can be reused. Mine is installed without any sealant and works great! You might consider also replacing the rubber grommets for PVC valve, etc. However, these are easy to replace at any time!
Old 04-25-2013, 06:41 PM
1983F1503004x4 1983F1503004x4 is offline
1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.
I've had my Fel-Pro cork gasket installed on my valve cover and had it off and on the motor over half a dozen times with no issues. Once she's tightened down, she kinda molds to the shape of the cylinder head and goes right back on EXACTLY like it came off.
I'll only use Fel-Pro cork. I don't like the rubber gaskets. Too slippery for my taste.
Just put some RTV on the valve cover and slip the gasket right down over it and let it set up before you put the cover on and tighten it down.
Old 05-03-2013, 12:27 AM
MS82F150XLT's Avatar
MS82F150XLT MS82F150XLT is offline
MS82F150XLT is starting off with a positive reputation.
Look for the obvious, when I took mine off my old engine I noticed a crooked rocker arm, 15$ later and #6 came back to life!!!
Old 05-25-2013, 09:24 PM
Wyowanderer's Avatar
Wyowanderer Wyowanderer is offline
Wyowanderer is gaining momentum as a positive member of FTE.Wyowanderer is gaining momentum as a positive member of FTE.
Installing a new valve cover gasket is pretty easy. I use FelPro gaskets. Pull the cover, clean it up, straighten the areas around the holes where the bolts have distorted the cover, and use gasket cement to stick the gasket to the cover. Put it back on (you painted it nice and pretty, right?) and tighten it down, not too tight. Done. Have an adult beverage and enjoy your work.
4.9 efi valve cover gasket Vonn4.9efi 1987 - 1996 F150 & Larger F-Series Trucks 21 01-16-2014 03:19 AM
P0300 1996 F150 4.9??? 88PONY 1987 - 1996 F150 & Larger F-Series Trucks 2 11-27-2013 10:56 PM
What color was the valve cover and air filter cover ericford1984 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 29 03-14-2012 09:50 PM
4.9L push rod cover gasket CABROCK Ford Inline Six, 200, 250, 4.9L / 300 7 06-15-2006 11:40 AM
Replacing valve cover gasket Ford4-life Ford Inline Six, 200, 250, 4.9L / 300 8 05-05-2006 05:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
