Lower shock bolts 01 Exp
I have a 2001 Exp that I change the shocks in. The lower blots have had it. Put in Grade 8 as replacements but they are lose. Were these metric? And if so what size? where can I order them from???? I called Ford and No longer stocked. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o> </o>
I wouldn’t worry about it but I have a thumping sound from the back end with bumps in the road. It started after the shock were in.<o></o>
<o> </o>
Also I still have the 4 corner leveling system from 2001. (Please note that Dodge is saying they are first with air ride for a truck) <o></o>
<o> </o>
<o> </o>
https://www.ford-trucks.com/forums/1...k-rattles.html
https://www.ford-trucks.com/forums/2...se-shocks.html
If you need anything else, just give a holler. Someone will be along and run the search function.
