1959 steering box - Ford Truck Enthusiasts Forums
1959 steering box
Old 04-24-2013, 09:48 AM
jamhh's Avatar
jamhh jamhh is offline
jamhh is starting off with a positive reputation.
1959 steering box
How did I tell what steering box my truck is equipt with. It looks like there could be three options. I can't see any casting numbers on or name on it?
the only casing no I can see are TAAK 3550 Ingersoll Machine
& how does the steering box separate from the steering shaft, it looks as it I have to take the steering wheel off and the shaft is part of the box? Is this correct
Old 04-24-2013, 08:04 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Perhaps if you posted a pic of your box it would help. Not knowing what box it is makes it hard to answer your next question.
Old 04-25-2013, 08:28 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
How does the steering box separate from the steering shaft, it looks as it I have to take the steering wheel off and the shaft is part of the box? Is this correct?
1957/58 and 1960 F100/250 2WD have a Gemmer gearbox. Some 1959 F100/250's 2WD's have Gemmer, some have a Saginaw gear box.
The Gemmer box has a casting number of: 3CC31
Old 04-25-2013, 02:01 PM
jamhh's Avatar
how do I post a picture successfully. I must be doing something wrong.
Old 04-26-2013, 07:16 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
Quote:
Originally Posted by spurredon View Post
Perhaps if you posted a pic of your box it would help. .
I'm sooooo NOT going there!
Old 04-26-2013, 10:33 PM
economan economan is offline
economan is starting off with a positive reputation.
I'm guessing that as it is likely a cdn. production truck the "Ingersoll" steering gearbox could have possibly been made in Ingersoll ont "?!?" I just swapped the one on my 58 last weekend for a slightly better one. Both were Ingersoll's & yes you have to take the shaft out right up to the steering wheel. I can't remember if on a stock truck you can slip it out of the column without completely removing the outer column I couldn't get enough room cuz of the exh. pipe coming off of my small block's manifold, so I hadta take the outer column off. , but this gave me a chance to re bushing my auto shifter (57 ford car) and tighten up the shifting mechanisim.
mikie
near Ottawa Canada
58 merc panel & 64 econoline p/u
79 4x4 steering marmon77 1973 - 1979 F-100 & Larger F-Series Trucks 23 01-05-2013 11:44 PM
Honk Honk!! kehoeautomotive 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-28-2011 01:34 PM
removing steering column 53 f350 tn.jed 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 05-19-2010 04:49 PM
Changing The Steering Box acw592 1999 to 2016 Super Duty 7 12-03-2009 10:16 PM
1994 steering loose as a goose SproutW 1978 - 1996 Big Bronco 10 02-22-2005 07:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
