Ford Ignition Module
So a few years ago when I wrecked the Wrongco.. I got a new front clip from what I believe was a 96' F250 or F350 with a 460 and ZF-5 manual trans.
On the fender when I got it was the ignition module.
Ignition module f1sf-12a297-c1a4L05A | Flickr - Photo Sharing!@@AMEPARAM@@http://farm9.staticflickr.com/8255/8661995349_90ac2059db_m.jpg@@AMEPARAM@@8661995349@@AMEPARAM@@90ac2059db
The numbers on it are F1SF-12A297-C1A and below that is 4L05A.
I just want to check, but I'm pretty sure that I already know the answer. The module won't work for 96' 351w correct? I had it on the truck when I first got it running again, but it ran really, really rich.
ICM
Probably. The black Motorcraft are hard to find. I am running a Taurus 6cyl in my 5.8 and my spare is from a straight six truck 300. Both work great.
The wiring connector and heat sink are the same but the computer controls the dwell and the wiring is different in the later year CCD design.
I bought a couple of Motorcraft grey ones which do not work so let me know if anyone wants them.
Of course pulling codes is the first step for running rich. Thermostat should be 195. Then if codes are good, look at O2, ECT and ACT.
Yes, the black ICM from the other truck will work just fine.
Some great info: Ford TFI Ignition Control Modules - FSB Forums
Some other info you may find handy:
Remote Mount Black CCD "Computer Controlled Dwell" ICM
Ford Bronco - Wiring Schematic
Motorcraft - DY1077 (supercedes DY679, DY667, DY645)
Ford - 5U2Z-12A297-D (supercedes F1PZ-12A297-A)
Wells - F139
Niehoff - FF413
BWD - CBE40
Standard - LX-241
NapaEchlin - TP29
Delphi - DS10056
Transpo - FM544
Wells - F139
Niehoff - FF413
BWD - CBE40
Standard - LX-241
NapaEchlin - TP29
Delphi - DS10056
Transpo - FM544
abyars111
02-12-2021 09:08 AM
jdon88
02-16-2004 07:09 AM
