59 F100 brake lights - Ford Truck Enthusiasts Forums
Old 04-23-2013, 09:56 PM
tbean tbean is offline
tbean is starting off with a positive reputation.
Does anyone have a picture of the brake switch and where it hooks into the panel? The 59 that I purchased was apparently redneck engineered. I have a drivers side brake light when the parking lights are off. But no parking light when the parking lights are on. The passenger side brake light doesn't work at all but the parking light works. Both blinkers work with and without parking lights on. Sorry if this is confusing.
Old 04-24-2013, 12:03 AM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Refyred
theodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to behold
From the factory it had a hydraulic switch on the brake M/C. Brake light should be wired through the turn signal switch. The brakes and rear turn signals share the same filament in the right and left rear bulbs the park lights have the other filament. You may need a wiring diagram to cypher the way the turn signal switch separates the front and rear turn indicators. The dash indicators run off the front turn lights so you don't light up the dash when you squash the brakes.
You can pickup a nice laminated wiring diagram off Evil bay for about 20$
Good luck!
Old 04-25-2013, 08:51 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
C1AZ-13480-A (replaced 0A-13480) .. Brake Light Switch (Motorcraft SW-24).
Threads directly into master cylinder, or to brass fitting that threads into master cylinder.
Notorious for getting gummed up with dirty brake fluid...and when this occurs, the little charmer no longer works.
Applications: ALL 1940/66 FoMoCo vehicles
Old 04-29-2013, 11:00 PM
Just for an update I'm still working on this. Hadn't had a chance to try anything yet cause I got caught up working on the new yoke and old rear end problem that I'm having. Hopefully I'll be driving soon
Old 05-06-2013, 06:56 PM
MARC's Avatar
MARC MARC is offline
MARC is starting off with a positive reputation.
brake light problem
first jump the brakelight switch. then go to the back and check the ground from the frame to the tail light housing. see if the brake lights work. THere mignt be a different poor connection on the other light housing. You could have an incomplete or poor ground between the frame and the bed. Many of the beds are mounted on a small rubber pad on top of the frame and require the mounting bolts to be the ground. Over time they can get rusty and create the poor contact. I have used the voltmeter/ohm meter to test resistance between light housing and frame. My quick fix was to run a ground wire to one of the lights. I had some kind of similar problem in past. that fixed it. (don't remember what the specific lighting display was.). I think it was no brake lights then.
Good Luck
Marc
Old 05-06-2013, 09:07 PM
Thanks Marc, I'll try that next. This one lighting problem is keeping me from having a legal driveable vehicle. I never thought three wires could be this problematic.
Old 05-08-2013, 11:18 AM
vincenteer vincenteer is offline
vincenteer is starting off with a positive reputation.
Hello tbean, the brake lights on my '59 were giving me fits. Then I downloaded the wiring diagram available on Google Images and figured out that the power for the brake lights comes out of one of the headlight switch circuit breakers, which was bad (go figure...). That switch is now being reproduced... in China, of course, but it is available. I replaced mine and it solved that problem. The brake lights also go through the turn signal switch, since brake and turn share the same lamp filament. This can be the source of other types of difficulties.
Old 05-09-2013, 02:31 PM
And..... Drumroll please...... The lights work. A big thank you to everyone especially Marc. The ground was the main problem. After that I fixed a broken wire in the steering column and bam, I have lights. Thank you all.
Tom
Parking Brake lalberts 1973 - 1979 F-100 & Larger F-Series Trucks 9 11-30-2016 02:49 PM
79 bronco no brake lights Jon.G Electrical Systems/Wiring 3 02-20-2015 05:55 PM
Parking Brake Switch Problem? stpete Excursion - King of SUVs 15 11-12-2014 07:13 AM
Parking brake switch speedx 1973 - 1979 F-100 & Larger F-Series Trucks 9 07-21-2010 03:48 PM
Brake makes parking lights come on?????????? acdc 1987 - 1996 F150 & Larger F-Series Trucks 10 02-17-2008 10:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
