'96 f150 4x4 pull to the left
Old 04-23-2013, 05:47 PM
garyd's Avatar
garyd
garyd is offline
I have a '96 4x4 with Firestone LE MT's with 1700 miles on them. Front end of truck was rebuilt in January and been on alignment rack twice. At first the truck was pulling to the right and the shop checked the alignment again, tightened up the steering box and rotated the front tires right to left. Now the truck wants to pull slightly to the left but not as bad as when it pulled to the right. Tire shop put front tires on balancer and they said tires run good. If I rotate them to the back will this straighten the tires up so when I rotate them back to front they will run straight. I thought about taking truck to a shop with a Road Force Balancer. Any ever have this problem?
Old 04-23-2013, 10:22 PM
1993_f350_2013's Avatar
1993_f350_2013
1993_f350_2013 is offline
how are your radius arm bushings? My truck started to pull right pretty good and i could not figure out what is was until i noticed my DRIVERS side radius arm bushing is totally toast.
Old 04-24-2013, 05:12 PM
garyd's Avatar
garyd
garyd is offline
The radius arm bushings and lower ball joints were replaced on both sides in January.
Old 04-24-2013, 06:28 PM
1993_f350_2013
is your frame bent?
Old 04-24-2013, 06:43 PM
garyd's Avatar
garyd
garyd is offline
No the frame is not bent. The truck pulled to the right and the front tires were rotated left to right and now it pulls to the left.
Old 04-25-2013, 09:03 AM
1993_f350_2013
get a new set of tires
Old 04-25-2013, 12:16 PM
dixie460's Avatar
dixie460
dixie460 is offline
He don't need a complete new set, just replace the left front. When that tire was on the right side, the truck pulled right. Moved to the left side, now it pulls left. This tire has what is known as a radial pull... a problem with radial tires where the steel belts begin to come apart inside and cause the tire to not roll straight. Can't be detected on a tire balancer, because a balancer don't give a damn about the tire as long as it's in balance!
Old 04-25-2013, 03:47 PM
1993_f350_2013
this sounds like a good reason!
Old 04-25-2013, 04:01 PM
thomabb's Avatar
thomabb
thomabb is offline
I vote bad tire.
Old 04-25-2013, 07:44 PM
garyd's Avatar
garyd
garyd is offline
If the tire is taken off the rim can a defect be found?
Old 04-25-2013, 09:07 PM
ItsAFord55's Avatar
ItsAFord55
ItsAFord55 is offline
throw the tire that you suspect is pulling on the rear and see if it stops
Old 04-25-2013, 09:11 PM
garyd's Avatar
garyd
garyd is offline
If I run this tire on the rear for several thousand miles will it run straight if I rotate it back to the front?
Old 04-25-2013, 09:13 PM
ItsAFord55's Avatar
ItsAFord55
no, youd still have to buy a new tire
Old 04-25-2013, 09:30 PM
ItsAFord55's Avatar
ItsAFord55
its caused when the tire is made and the radials in it arent prefectly aligned and causes a smaller diameter on one side of the tire when inflated.
Old 04-26-2013, 06:30 AM
dixie460's Avatar
dixie460
dixie460 is offline
I doubt you'd be able to see anything, so no. As was suggested above, you can try putting it on the rear axle instead, but it's still a bad tire. I wouldn't trust it to hold together for too long, eventually the radial belts will probably start coming apart. When this happens you CAN see it, the tire will be out of round by then and you'll not only see it but also feel it when driving.
With only 1700 miles on it, the manufacturer should help you out with a warranty replacement.
jimbo285
10-04-2012 06:06 PM
WillFargo
09-10-2010 10:23 AM
vettman
02-25-2009 10:29 PM
shanesF150
02-28-2005 05:13 PM
Quantum
02-18-2000 12:34 PM
Quick Reply: '96 f150 4x4 pull to the left
