My oil dipstick broke. Need suggestions for a replacement.
Let's get this out of the way: 1992 F-250 7.3l non-turbo diesel, automatic, may or may not make waffles for me if I ask it nice enough.
Anyways, today I wanted to check up on my oil level, because I'd rather this truck not blow up. The dipstick felt pretty stuck in there. Using the kind of logic only an A-student in college can use, I decided more force was needed. The stick eventually came out after a huge fight (still intact), so I wiped it, stuck it back in (this was a huge chore), and then when I tried to remove it again, that's when it snapped.
Maybe 4-5 inches of dipstick came out, mostly what looked like a tube part. The rest of the dipstick is still in the tube going to the engine.
Took it to the mechanic, and he told me I'm just gonna have to replace the whole thing. He also thinks that this was the wrong dipstick for the truck. Oh well.
Now I'm looking for a replacement dipstick and tube. So far, all I've found is the universal stuff O'Reilly has. Anyone have any experience using these, or would I be better off going to Pick-N-Pull? And, speaking of the junkyard, do I have to get the part from a diesel specifically, or can I get the dipstick stuff from a different engine like the 460?
Anything else I should worry about related to this?
You may have a hard time putting in the dipstick that's supposed to be there if that one is still in there. You may be able to drop the oil pan and pull it through. That's what I'd try.
Yep, that's also an option. I'd probably drop the oil pan because it's probably not a bad idea to clean it out anyhow. Not hard to do, pretty much straight forward.
P4IN COMM4NDO
13
10-28-2016 07:15 PM
messymom
01-30-2015 04:36 PM
