Trans crossmember delete - Ford Truck Enthusiasts Forums
Old 04-23-2013, 11:24 AM
blackedout blackedout is offline
blackedout is starting off with a positive reputation.
I have swapped a CV IFS into my 59. I had to get the AOd out of it so I cut the original trans mount out. I fabbed my own trans mount that bolts to the tail shaft. Is it ok to leave the original out? Most cars I have worked on don't have a chassis brace under the trans.... I'll weld something in it is a safety issue.
Old 04-23-2013, 03:28 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
The original crossmember, if it's the one I think you're referring to, also stiffens the frame where the original leaf springs. That the one? If you don't have leaf springs, have enough reenforcement for the cv ifs and have a mount for the trans, I don't see a need for it. That's just my opinion. I'm sure some with more experience doing IFS installs will weigh in
Old 04-24-2013, 11:47 AM
Ok, so that was for the leafs makes sense why it was so beefy. HERE is my build thread (on this forum) If anyone else would way in I would be very appreciative.
Old 04-26-2013, 06:22 PM
vntgtrk's Avatar
That trans Xmember you made is HUGE!!! Nice work! I'd have no problem pulling out the original. In fact it's almost imperative. If you leave it in place, Murphy's Law says your trans will die right away. Make it easy to pull and you'll never have trans problems
Old 04-26-2013, 08:00 PM
thrifty's Avatar
thrifty thrifty is offline
thrifty is starting off with a positive reputation.
There are 3 cross members on your frame. One in the front, the middle,(bell housing) and one in the rear. Are you talking about the Bell housing cross member? They are all important other wise they would have not designed it that way. I have seen people take out the bell housing C. member out and that is way to much space with no bracing. Your frame will flex with the C. members. So imagine what it would do with out it. Hope that's the one u r talking about.
Jonesy
Old 04-26-2013, 08:28 PM
thrifty's Avatar
I forgot about the other cross member that the emergency brake cable hooks up to.
Old 04-26-2013, 09:58 PM
vntgtrk's Avatar
Quote:
Jonesy
Isn't there an added Xmember for the CV clip? And then another for the trans? That's where many peeps, me included, don't wish to mess with this kinda stuff. I'm just not that confident in my abilities. Another idea, and what I was gonna do if I ran a 5.0/AOD, was to knock out the rivets and replace them with bolts so this Xmember could be removed if needed. You'd have to brace the heck outa the frame and not move it till it's put back, but at least trans work wouldn't be as bad
Old 04-28-2013, 09:40 PM
frankcowan's Avatar
frankcowan frankcowan is offline
frankcowan is starting off with a positive reputation.
The c-channel frame rails are really not that strong without the cross members. That's why a lot of people box the frame when they do modifications. I swapped in a 390 FE that required removing the trans cross member. I added a deeper cross member below where the original was. Fabbed it from an old c-channel rear bumper. Provided some strength and a place to run the right front brake line. Just didn't feel comfortable not having something there.
Old 04-28-2013, 10:01 PM
vntgtrk's Avatar
Frankc, that makes sense and it looks like you have clearance in case your trans defecates the bed. Nice craftsmanship. And kudos for using what you have instead of spending a bazillion bucks
Old 04-30-2013, 09:17 PM
thrifty's Avatar
Good call on the c.v clip cross member. vntgtrk I forgot all about that. Glad somebody is taking up my slack. I was trying to show how important the cross members are.
Frankcowan is correct about the boxing the of frames. Good thinking on still using the original c. member and modification.
Old 05-09-2013, 08:33 AM
NIce guys.. I do have the CV cross member with boxing around it. I will drive it without the cross member and see what happens. I can always fab something if needed.
4.6/Crown Vic install question Jim 54 panel 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 07-28-2013 01:57 PM
transmission vibration damper? Roger1960 Aerostar 3 06-19-2011 10:31 AM
4x4 linkage whistle1516 1973 - 1979 F-100 & Larger F-Series Trucks 0 03-18-2011 10:53 AM
Motor mount cross reference question sohcslammer 1973 - 1979 F-100 & Larger F-Series Trucks 14 11-30-2009 07:21 PM
will 292 mount up to 3speed trans 56 f100 bbslamjam Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 6 01-23-2007 08:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
