Towing with AOD?? - Ford Truck Enthusiasts Forums
Towing with AOD??
Old 07-26-2002, 06:03 PM
Redneckerson Redneckerson is offline
Redneckerson is starting off with a positive reputation.
Towing with AOD??
Old 07-28-2002, 11:36 PM
jsatt1 jsatt1 is offline
jsatt1 is starting off with a positive reputation.
Towing with AOD??
I have an 88 f-150/302/AOD. When towing a trailer should i stay in overdrive as with normal driving or shift into drive...Different trailers ranging from 3000 to about 5200lbs, mostly highway miles.
Thanks for any input..
Jeff.
Old 07-28-2002, 11:57 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
Towing with AOD??
If it keeps shifting in and out of OD when there is a slight grade, leave it out. If it holds most of the trip, keep it there. When the tranny keeps up/down shifting is when you need to leave it out of OD.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Superduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Top speed is 65mph, Go Baby Go!
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Tailgate mods 1978 - 1996 Big Bronco 6 05-25-2002 04:08 PM
Cams broom FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 11-24-2001 01:46 PM
Tags
aod, ford, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
