96 F150 ECU code location...???
redlead, just a question about 96 trucks..My haynes manual says that you must go to Ford to pull trouble codes from this ECU...(ie you cannot jumper the leadas and monitor with a meter or flash outs on the dash light)
What expereince have you had with this? did you have to buy a code reader?
I am looking at buying a 96 F150, and worndering if I am gonna have some headaches in that department...
Thanks
Thanks
I bought a code reader from Checker for my 96 E250. It seems to work really good it is a new system on the 96 and new vehicles. With numbers and letters for codes that is why you can't jumper the connector and read the flashes. I have been having trouble with my 96 since about 50,000 MI (now 115,000 MI) and I don't know if it is because of the first year problems with this new system or what.. My 94 seems to run better and have more power, and it has 215,000 MI on it. I would think about maybe and older or a newer one and not the first year for any new stuff like motors and ignition stuff. Ford doesn't have the 4.3 anymore.
good luck
good luck
UNTAMND
01-14-2013 03:20 PM
G2IC_Wraith
Electrical Systems/Wiring
19
08-26-2006 10:20 AM
redlead3
07-08-2002 06:22 PM
redlead3
20
02-14-2002 10:59 AM
