Super Swamper TSL Pics - Ford Truck Enthusiasts Forums
Old 04-23-2013, 09:18 AM
PA74F250's Avatar
PA74F250 PA74F250 is offline
PA74F250 is starting off with a positive reputation.
Hey guys I was wondering if anyone over here can help me out. I'm looking for pics of a 38x12.5-16.5 mounted vs a 16/38.5-16.5. I'm trying to help a friend decide on width for purchasing. He has a plenty of clearence so its basically all about looks not even performance.
Thanks
Old 04-23-2013, 10:14 AM
mafia_jon mafia_jon is offline
mafia_jon is starting off with a positive reputation.
i believe these are 13.5
Old 04-23-2013, 03:43 PM
thekingofcows's Avatar
thekingofcows thekingofcows is offline
thekingofcows is gaining momentum as a positive member of FTE.
Quote:
<table class="tborder" align="center" border="0" cellpadding="6" cellspacing="1" width="100%"><tbody><tr><td class="thead" colspan="2">Today 10:14 AM</td> </tr> <tr title="Post 13092669" valign="top"> <td class="alt2" align="center" width="125">mafia_jon</td> <td class="alt1">
i believe these are 13.5 </td></tr></tbody></table>
Do you know what size Coil Springs are under that Bronco, we are about to do a solid axle swap on an 86 F150, that's the stance I'm looking to get out of it.
Old 04-23-2013, 05:25 PM
77mud's Avatar
77mud 77mud is online now
77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.
38x12.5/15 on a 10" wide rim.
Old 04-23-2013, 06:36 PM
fatdan460 fatdan460 is offline
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
what's the intended use of the truck? personally i hate skinny tires unless it's a mud racer where it might benefit from pizza cutters. trail riding and playing in some mud and i'll take the wider option every time. more flotation and more side wall to flex and buldge if you air down tires. only reason i'd run skinnies is if i was limited by clearence.
and just for a simple tires for dummies answer: wider tire=more contact patch=more traction.
Old 04-23-2013, 06:42 PM
77mud's Avatar
Wider tire also = harder to turn...
BTW back tires on that truck are 15/38.5x15's also on 10" rims
Old 04-23-2013, 06:51 PM
PA74F250's Avatar
Thanks for the pics guys. I think for the height of his truck he's going to need a wider tire to look right.
Old 04-23-2013, 06:54 PM
PA74F250's Avatar
Myself I like the wider tire as you can see in my avatar. The use of his truck is basically drive it and look good. I'll post a pic of it when I get home but its a 77 highboy that just had a complete resto...everything is new. It will most likely never see rain again let alone mud.
Old 04-23-2013, 08:06 PM
PA74F250's Avatar
Here it was as junk
Old 04-23-2013, 08:08 PM
PA74F250's Avatar
Here is the best side shot after the donor body and chassis were complete. You can see with the 31" tall tire its got plenty of room and makes me think the skinny will look funny.
Old 04-23-2013, 08:11 PM
PA74F250's Avatar
As of a week or so ago before it was all out back together. I don't have any other pics for now but we need to get some tires ordered.
Old 04-23-2013, 08:33 PM
alpha/omega's Avatar
alpha/omega alpha/omega is offline
alpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to allalpha/omega is a name known to all
Are those 4 or 6" springs?
Old 04-23-2013, 08:44 PM
PA74F250's Avatar
Well they are listed as 4" for a highboy or 6" for a lowboy.
Old 04-23-2013, 09:25 PM
Old 04-23-2013, 11:30 PM
just for looks=always go wider as well. not many trucks look "good" with pizza cutters....
were can i find tire tubes for my 38.5x16xR16.5 tires? 79f250ranger Brakes, Steering, Suspension, Tires, & Wheels 1 08-15-2016 08:24 AM
1974 F250 Highboy 38x12.50x16.5 Swampers joshcwa 1973 - 1979 F-100 & Larger F-Series Trucks 41 09-01-2012 11:30 AM
post pics of ur 73/79 f150 on 38.5 1979fordf150rebel 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-31-2012 10:29 AM
e4od line fittings on trans. brad7.3 1994.5 - 1997 7.3L Power Stroke Diesel 7 03-23-2009 09:22 PM
Will These Tires Fit My Rims? rebelbob Brakes, Steering, Suspension, Tires, & Wheels 4 08-17-2003 11:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
