Fluid Maintenance Time Questions - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-23-2013, 10:16 AM
X1Lightning's Avatar
X1Lightning X1Lightning is offline
X1Lightning is starting off with a positive reputation.
I want to go through and change all the fluids in my truck, is there a chart some where that specifies what oils are needed for each location and how much?
Old 04-23-2013, 10:26 AM
PSDlongbox's Avatar
PSDlongbox PSDlongbox is offline
PSDlongbox is gaining momentum as a positive member of FTE.PSDlongbox is gaining momentum as a positive member of FTE.
Owners manual?
Old 04-23-2013, 10:30 AM
bought my truck used, so it didn't come with one
Old 04-23-2013, 10:32 AM
PSDlongbox's Avatar
Quote:
Yeah same here. I believe there is a list in the FAQ.
Old 04-23-2013, 10:54 AM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Old 04-23-2013, 11:58 AM
Thanks for the documents
how do i identify if i have a dana rear end or not?
Old 04-23-2013, 11:59 AM
Ridenred333 Ridenred333 is offline
Ridenred333 is starting off with a positive reputation.
Theres a tag on the axle get the code off of there.
Old 04-23-2013, 12:13 PM
Disgruntled Texan
Since you have a dually F350 is should be a Dana. But, for ****s and giggles count the bolts on the cover, the D80 should have 10.
Transmission Fluid Change HiTech Modular V10 (6.8l) 6 08-13-2002 08:12 PM
Tranny Fluid? dzk007 Aerostar 2 04-13-2002 12:13 PM
Differential Fluid recommendations StrangeRanger 1987 - 1996 F150 & Larger F-Series Trucks 4 11-14-2001 04:32 PM
transmission lost fluid fiddy 1987 - 1996 F150 & Larger F-Series Trucks 3 06-10-2001 11:15 PM
Tranny fluid type? EJonesJr 1973 - 1979 F-100 & Larger F-Series Trucks 14 06-03-2001 10:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
