Totally new suspension - Ford Truck Enthusiasts Forums
Old 04-23-2013, 07:46 AM
Gicknordon's Avatar
Gicknordon Gicknordon is offline
Gicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to all
I just found this video on youtube in my recommended videos. This seems like a very cool idea and would be simple to add to many cars.
Old 04-23-2013, 08:33 AM
Gicknordon's Avatar
i guess ts not totally new. Its kind of a more sophisticated version of a gocart suspension.
Old 04-23-2013, 09:23 AM
Dobies4life's Avatar
Dobies4life Dobies4life is offline
Dobies4life is starting off with a positive reputation.
Didnt Mercedes do a hydraulic suspension decades ago? I know they were the originators of fuel injection in the 50's. For some reason this just screams old Mercedes tech.
Old 04-23-2013, 09:40 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
That was Citroen that had hydraulic suspension.
Old 04-23-2013, 09:52 AM
I knew I had read somewhere about it. Thank God for people older and wiser than me!
Old 04-23-2013, 02:25 PM
aussiecowboy aussiecowboy is offline
aussiecowboy is gaining momentum as a positive member of FTE.aussiecowboy is gaining momentum as a positive member of FTE.
Ross is right, Citroen did it first but Mercedes did use it in the early 60s on the 600 Grosser which had hydraulic everything.
Old 04-23-2013, 02:53 PM
Gicknordon's Avatar
Was the suspension on the spindle the same though?
Old 04-23-2013, 03:44 PM
ALBUQ F-1's Avatar
postin' fool
No, the Citroen at least used a hydropneumatic bulb that acted on the upper A-arm, more or less.
Old 04-23-2013, 05:05 PM
Gicknordon's Avatar
Ok i see. I wonder if this could be adapted to an original solid front axle to get the real look of a solid axle but the ride of an ifs.
Old 04-23-2013, 06:30 PM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
Very cool setup...looks to me to be more like the old Chevy knee-action setup than some of the others. Solid mounted axle with suspended spindles at the wheels.
Old 04-23-2013, 07:35 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Interesting concept, but not an improvement IMHO. There is no provision for camber gain with roll or antidive with braking.
Old 04-24-2013, 01:29 PM
das54's Avatar
das54 das54 is offline
das54 has a very good reputation on FTE.das54 has a very good reputation on FTE.das54 has a very good reputation on FTE.
To understand antidive look at the upper control arm. The pivot is angled upward toward the front. Someone recent said their MII front was installed backwards and the upper control arm sloped downward (really bad). Anyway, when braking there is a horizontal force acting in the forward direction on the upper ball joint and the upper control arm geometry turns this force into a downward force at the ball joint. The downward or antidive force is proportional to the braking force. Pretty cool. But how effective is this? I don't think McPherson struts have the same effect but most cars nowdays use that type front suspension.
Old 04-24-2013, 06:41 PM
AXracer's Avatar
Easier explanation: brake dive is when the front brakes are applied the resistance on the wheel rotation makes the front end want to tuck under,
similar to what happens when you apply only the front brake on a motorcycle. Anti-dive is geometry built in that resists that force.
Video, What about this offroad Vehicle? Robert46 General Automotive Discussion 5 05-16-2014 04:07 AM
Good locking hub service video and an Ex stuck on the beach video EXv10 Excursion - King of SUVs 4 11-19-2013 05:26 PM
mud bog video's fordsrgrt Offroad & 4x4 1 07-03-2013 10:34 AM
GIRLS AND TRUCKS Scooter101 General NON-Automotive Conversation 9 01-16-2013 07:14 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
