Frame boxing
Hey Heavy, I to purchased the no limit package and it came with the under the floor booster etc. My package also came with some linkages and brackets. I cleaned up the area and made it all work. Part of the process was to cut out about an inch of the brake pedal and reweld it together for a more comparable position.
In my case the only thing I reused is the brake pedal and then plug it with a CPP bolt kit for deleting the extra pedals.
(hope the links work my iPad is giving me issues)
IMG_3646.jpg Photo by svtxcno | Photobucket
I went with a hanging pedal assembly from Engineered Components. It mounts to the firewall. I made a big doubler and also had to make up a bracket to tie the back end to the dash.
Here it is on the bench before installation. It is set up for some offset. It puts the pedal where you want it, but keeps the master cylinder away from the engine.
revamp1953f100
06-13-2018 03:17 PM
tjdad62
01-14-2011 06:22 PM
mrkpearson
04-18-2008 09:25 AM
