No start after 30 secs. of running - Ford Truck Enthusiasts Forums
Old 04-22-2013, 12:08 PM
DaGovna DaGovna is offline
DaGovna is starting off with a positive reputation.
I have a 2005 6.0 that runs for 30 secs then it lugs down and will not start until you let it sit for 5 mins.Connected scanner no codes while monitoring injection pressure with scanner psi actual is 840 while running matches desired psi. when it starts to lug down at idle desiredis 1000 and the actual starts to ramp up all the way to 2500 psi then it shutts down. will restart in 5 mins. but the same thing happens again? IPR has been changed. Im thinking there is some kind of resriction in the high pressure oil system causing pressure to go up? Anybody have any ideas ?? thanks for the help
Old 04-22-2013, 12:14 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Thread moved to the 6.0L Powerstroke Diesel forum.
2004 6.0 powerstroke with rough starting problem 2004_6.0 powerstroke 6.0L Power Stroke Diesel 8 10-21-2014 09:52 PM
P1280 Truck runs but with a slight rough spot patrick77598 1999 - 2003 7.3L Power Stroke Diesel 3 10-30-2013 07:51 AM
07 explorer 4.0 hard start returnless system tunedbyear Explorer, Sport Trac, Mountaineer & Aviator 4 01-14-2013 05:49 PM
Hard warm start calgary96f150 1987 - 1996 F150 & Larger F-Series Trucks 14 02-24-2012 10:04 PM
fuel pump check valve??? LxMan1 Fuel Injection, Carburetion & Fuel System 7 11-10-2009 04:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
