What in the world could cause this??!! - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 04-22-2013, 10:48 AM
Splatts's Avatar
Splatts Splatts is offline
Splatts is gaining momentum as a positive member of FTE.
Driving at about 70mph, vibration/bouncing (like driving on them concrete highways with all the seems). Then it slowly goes away for a few seconds then slowly starts this bouncing crap again. I have got all new u-joints on the driveline, and front end, new ball joints up front also and new carrier bearing and driveline has been balance in the last few months. I was driving to go turkey huntin and really tried to pay attention to what was goin on. Most of the times before I thought it was the California highways but I'm in Washington and 395 is a nice highway. It stinking rattles your teeth then slowly stops, then slowly starts doin it again. It was kinda creepy driving like this for 2hrs, I hope I didn't cause any more damage. No more road trips for the beast until I get this handled!!! HELP!?!?!? Lol
Old 04-22-2013, 11:48 AM
richdawg's Avatar
richdawg richdawg is offline
richdawg has a good reputation on FTE.richdawg has a good reputation on FTE.
IDK Does it do it at other speeds as-well or just around 70. It sounds like it could be causing more damage if you keep driving it. I would take it to like Les Shawbs and let them check it out and give you an estimate, at least then you would most likely know what you are dealing with, any other tire store may be fine too I have just had good luck with them.
Old 04-22-2013, 12:23 PM
tshrager's Avatar
tshrager tshrager is offline
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
How old are your tires? My bosses IDI cab and chassis has a slight shimmy. One of the steer wheels is cracked.
Old 04-22-2013, 01:00 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
A split tire will rattle your teeth ...
Old 04-22-2013, 01:24 PM
Splatts's Avatar
They maybe have 6k miles on them and not even a year old. They are BFG all terrains. It's weird how it come then slowly goes away then slowly developes back to bouncing and vibrating.
Old 04-22-2013, 01:42 PM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
sounds like a wore out shock.
the wheel starts bouncing a bit due to uneven road conditions. if speeds are rite, the slight hop will steadily get worse till it hits a certain point, then fade. then start the cycle all over again.
Old 04-22-2013, 02:06 PM
FI460's Avatar
FI460 FI460 is offline
FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.
Did you have your tires rebalanced? My bfgs needed balancing constantly.
Old 04-22-2013, 04:47 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
If you haven't already, replace the track bar bushings and see if that helps.
Old 04-22-2013, 04:53 PM
nossliw's Avatar
nossliw nossliw is offline
nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.
Quote:
Nailed it! 80% of the time this was the culprit with most HD trucks brought in, double check the bolts for the mounts as well....Extremely prominent in Jeeps too.
Hope your part of that 80%
If it does it at only one speed its harmonic and is either tires out of balance(or tire related) or worn shocks, if you replaced everything else you mentioned.
Old 04-23-2013, 12:13 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
What happens if you jerk the steering wheel one way, then the other? Will it smooth out?
Old 04-23-2013, 06:35 AM
427 fordman's Avatar
427 fordman 427 fordman is online now
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Quote:
I go in the ditch and wreck my truck..........
Old 04-23-2013, 09:29 AM
nateairman's Avatar
nateairman nateairman is online now
nateairman is gaining momentum as a positive member of FTE.
Haaa haaa. Good one Glen!
I know what you ment but the response was great!
Thanks for the morning chuckle!
Old 04-23-2013, 11:38 AM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Have you tried rotating the tires?
Old 04-23-2013, 11:42 AM
TyBragg's Avatar
TyBragg TyBragg is offline
TyBragg is starting off with a positive reputation.
Quote:
hahahahahha....I cracked up when I read this! You walked right into that one Glenn!
Good one Darin.
Old 04-23-2013, 12:42 PM
I'm good at walking into things like walls, trees, etc. LOL Darin is the drag stripe driver and doesn't move that wheel a fraction of a inch, so yeah, good response Darin, LOL
Need help from the noise/vibration detectives blanes 1987 - 1996 F150 & Larger F-Series Trucks 9 03-27-2016 07:26 AM
Rear Truck Bounce sduce 1997 - 2003 F150 3 02-06-2015 01:10 PM
Driveline to transfer case problem riot04 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-04-2014 01:50 PM
Driveline Bounce/hop DHamSTER 1999 - 2003 7.3L Power Stroke Diesel 15 08-18-2014 10:27 PM
Bouncing Front End saratoga2011 6.2L V8 10 09-01-2013 09:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
