What in the world could cause this??!! - Page 3 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #31
Old 07-24-2013, 07:47 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
I know you have the spacers because your tires are 315s, but do you think 285s would require the spacers?
  #32
Old 07-24-2013, 07:48 PM
DanielT28's Avatar
DanielT28 DanielT28 is offline
DanielT28 is starting off with a positive reputation.
Tires could be seperating inside
  #33
Old 07-24-2013, 08:12 PM
Splatts's Avatar
Splatts Splatts is offline
Splatts is gaining momentum as a positive member of FTE.
The only way I found this out was the guy at the tire shop just had te same issue with another customer. You can see wear marks on the outside of the spacer. The outer rim isn't centered. There is play between the lugs and the holes in the rim. Having the lip on the outer side of the spacer centers the rim and doesn't allow it to move off center. The guy swapped out the spacers on the other vehicle with spacers that have the lip for the outer rim to sit on and bouncing problem solved.
  #34
Old 07-24-2013, 08:54 PM
Splatts's Avatar
Here is a pic of the spacers with the lip on them
  #35
Old 07-24-2013, 09:16 PM
95350PS's Avatar
95350PS 95350PS is offline
95350PS is starting off with a positive reputation.
Where did ya buy em the bouncing issue sounds exactly like mine I have 3 inch spacers in the rear and it does the bouncing right around 35mph also and has a vibration I cannot find where its coming from makes so much sense now lol
  #36
Old 07-24-2013, 09:28 PM
Splatts's Avatar
Arrowcraft.com is where they are at.
  #37
Old 07-24-2013, 09:32 PM
Splatts's Avatar
Take off your outer dual and look at the marks from the rim on the spacer and you will know what I'm talking about.
Need help from the noise/vibration detectives blanes 1987 - 1996 F150 & Larger F-Series Trucks 9 03-27-2016 07:26 AM
Rear Truck Bounce sduce 1997 - 2003 F150 3 02-06-2015 01:10 PM
Driveline to transfer case problem riot04 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-04-2014 01:50 PM
Driveline Bounce/hop DHamSTER 1999 - 2003 7.3L Power Stroke Diesel 15 08-18-2014 10:27 PM
Bouncing Front End saratoga2011 6.2L V8 10 09-01-2013 09:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
