I looked at all the topics but all they are is arguing over its bad or good, I am gonna do mine RIGHT not half ***, now my ? Is what all would I need for a 3-2 inch body lift to make it safe and efficient ?? Oh I already have a 4in suspension
Get Polyurethane cab mount bushings while your at it. You may need to fix your frame mounts. Most of the time you can't tell their condition untill a bushing falls through. Now is the time to take it all apart and check their condition and add the poly bushings. They will stiffen it up quite a bit. There is nothing wrong with a body lift, I've had on for years and wouldn't ever take it off. Makes it SO much easier to work under and clean.
