Sway bar & air bags - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Sway bar & air bags
Old 04-21-2013, 10:56 PM
abranz abranz is online now
abranz is starting off with a positive reputation.
Sway bar & air bags
I installed a hellwig sway bar which improved body roll and rear steer tremendously. Air lift bags corrected the rear sag in particular with a load or towing. Installs went fine. Thought I would post my results for others contemplating suspension upgrades. These two where huge improvements.
Anthony
Old 04-22-2013, 01:29 AM
Technologiq's Avatar
Technologiq Technologiq is offline
Avid GM Hater
Technologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud ofTechnologiq has much to be proud of
Quote:
Anthony
How difficult was the install on both? Which air lift bags did you get?
Old 04-22-2013, 08:31 AM
9905 9905 is offline
9905 is gaining momentum as a positive member of FTE.9905 is gaining momentum as a positive member of FTE.
interested also
Old 04-22-2013, 09:07 AM
ScaldedDog's Avatar
ScaldedDog ScaldedDog is offline
ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.
It looks like he said Air Lift. I did this same thing years ago, and have been happy. Install was easy, other than securing an 8000lb truck on jackstands. The OP's experience is much more recent than mine, so he can probably fill in the details I've forgotten.
Mark
Old 04-23-2013, 01:43 AM
Install was straight forward on both. The instructions for the hellwig bar left a lot to be desired but the airlift bag install ones were better. Nothing other than regular hand tools, jack, stable stands, and beer. I posted this because the change was so dramatic I couldn't believe it. Far more than most changes I've done. Well, the front leaf spring v-code springs where quite a change also since the oe leafs were shot. This tank really is beginning to drive great. Many thanks to those on this site that paved the way for the rest of us.
Old 04-25-2013, 08:27 AM
Avid GM Hater
Did you remove the bumpstops when you installed the airbags?
sway bars Morning Wood 1999 to 2016 Super Duty 22 04-18-2016 10:39 AM
Hellwig Big Wig Rear Sway Bar LariatRick 6.7L Power Stroke Diesel 42 08-21-2015 11:50 AM
Rear sway bar on f250 bdarr4014 6.7L Power Stroke Diesel 7 12-29-2011 07:54 AM
Why do I need a rear sway bar? H1449-6 Excursion - King of SUVs 20 09-18-2008 10:41 AM
timbren vs. air bags sipers Excursion - King of SUVs 9 03-31-2005 08:35 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
