cooling
Old 04-21-2013, 08:19 PM
zombiefied 247's Avatar
zombiefied 247
zombiefied 247 is offline
cooling
I was wondering... will a 3 row radiator be enough to keep my 302 cool
Old 04-22-2013, 01:08 AM
Mervy49's Avatar
Mervy49
Mervy49 is offline
I don't think you should have any problems with a three core as long as it is clean. Are you using the shrouds and stock fan? If you going with an electric fan that should be ok.
The ford factory put two core rads in front of 351 motors in the mid 70's and they worked fine from what I can remember.
Old 04-22-2013, 01:51 AM
aussiecowboy's Avatar
aussiecowboy
aussiecowboy is offline
Depends on width. I'm cooling a 351 with a 3 row in the Aussie heat, no problems.
Old 04-22-2013, 07:31 PM
zombiefied 247
thanks for the info guys!!!! i will be using the stock fan and also a shroud
learpilot
11-02-2008 07:04 AM
McLeod
1966 - 1977 Early Broncos
03-01-2006 10:10 PM
Sean351
03-23-2004 07:30 AM
68 351 bronc
18
03-15-2004 07:49 PM
lowcountry
13
06-26-2003 12:02 PM
Quick Reply: cooling
