Hydroboost - Ford Truck Enthusiasts Forums
Hydroboost
Old 04-21-2013, 09:01 PM
strokinout strokinout is offline
strokinout is starting off with a positive reputation.
Hydroboost
Hey guys. I've searched a bit and am not turning up much info. I've ran across a post mentioning that the hydroboost out of a chevy astro van would swap almost directly. I went ahead and grabbed one today out of the junk yard but didn't have time to grab the hoses for it. Has anyone done a hydroboost swap with a unit from an astro van?
Old 04-21-2013, 09:19 PM
racerwoody racerwoody is offline
racerwoody is starting off with a positive reputation.
I want to do this mod myself. I thought you just used the F350 setup from this year truck. I know the astro setup is popular in the bronco crowd. Look around those boards for info on the system.
Old 04-21-2013, 09:28 PM
I thought 1996 f-350's used vacuum assist.
Old 04-21-2013, 10:20 PM
DIYiT's Avatar
DIYiT DIYiT is offline
DIYiT has a good reputation on FTE.DIYiT has a good reputation on FTE.
I can't speak to the chevy setup, but most of the time one sees the use of an 8th gen F-Superduty (F-450) hydroboost setup.
Old 04-21-2013, 10:22 PM
Yeah, I know but for $25 I couldn't pass up the chevy hydroboost if it'll work.
Old 04-21-2013, 10:24 PM
I thought the diesel trucks had hydro...
Old 04-21-2013, 10:58 PM
Nope. LKQ in Daytona here has a powerstroke (or at least it had one when it came in) f-350 and the first thing I started to think about was hydroboost. May go back tomorrow and if I do, I'll get pictures that show the vacuum booster in it. Needless to say I was kinda disappointed because I thought I was about to score.
Old 04-21-2013, 11:04 PM
hmm, well I'll be watching this thread then LOL.
Old 04-21-2013, 11:29 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
use the proper system for the hd trucks guys.your adding hydroboost primarily for increased safety.don't skimp.use the f-super duty/450 system.it's all direct bolt in.perhaps a little modding if you keep an aluminum 250/350 master,but that's about it.
http://www.ford-trucks.com/forums/10...st-brakes.html
Old 04-22-2013, 12:03 AM
Go figure. I did some more digging and it seems the hydrobooster was an option on f-350's with a diesel. Will be going back tomorrow for the hoses and the reservoir.
Old 04-22-2013, 07:54 AM
not that i know of.as far as i know (pre 99 SD era) the only hydroboost option for the f-series was the f-super duty (f450) and all of those 8th and 9th gen's got hydroboost,despite being a 460 or a diesel truck.
none of the hd platform pickup (250/350) nor the 350 cab n chassis received hydroboost,despite engine size or type.
not to say you can't find a pickup with hyrdro in a salvage yard of course,but it wouldn't have been factory.
Hydroboost conversion problems... Please help!!! carguy29 1973 - 1979 F-100 & Larger F-Series Trucks 10 09-30-2015 05:05 AM
Are blower motors compatible between different makes? purpleaustin Cooling, Heating, Ventilation & A/C 5 05-28-2015 12:39 PM
Hydroboost conversion question 68murc 1967 - 1972 F-100 & Larger F-Series Trucks 7 02-24-2015 08:54 PM
Converting to Hydroboost xmontex4 1999 to 2016 Super Duty 6 09-24-2014 10:18 PM
HYDROBOOST REBUILD F-250 restorer 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-05-2012 04:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
