WHAT YEAR DID FORD 302 TRUCKS ???? - Ford Truck Enthusiasts Forums
Old 04-21-2013, 08:41 PM
kermmydog's Avatar
kermmydog kermmydog is offline
kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.
Question WHAT YEAR DID FORD 302 TRUCKS ????
What year did the Ford Trucks with 302s start to use Roller Cams? I searched but couldn't come up with an answer.
Thanks in advance.
Craig
Old 04-21-2013, 11:42 PM
jimbbski jimbbski is offline
jimbbski is starting off with a positive reputation.
No Ford Truck 302 got a roller cam. The Explorer did get a roller can starting in 1996. Now all of the blocks that Ford made after 1985 were cast so that a roller cam could be installed after a few modifications were made and the roller cam parts were sourced.
Old 04-22-2013, 01:26 AM
jhg_12's Avatar
jhg_12 jhg_12 is offline
jhg_12 is starting off with a positive reputation.
roller blocks with roller cams were 93.5 on in the 5.0
Old 04-22-2013, 07:25 AM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
Roller cams were introduced in the 1992 model year with the same "base roller cam" the Crown Vics had. 1994 they got a far better cam, the F4TE which was also used in the roller 5.8's and later in the Explorer/Mountaineer 5.0
Old 04-22-2013, 08:52 PM
kermmydog's Avatar
Question
Quote:
So to get things straight in my mind my 95 F150 4x4 with factory installed 5.0 (302) has a roller cam? What brought this up was the oil & DZZP. If my 95 isn't a roller cam then I want to add an additive to make up for the lack of zinc so critical to hydraulic flat tappet cams.
Thanks,
Craig
Old 04-22-2013, 09:09 PM
Quote:
Thanks,
Craig
Yes, your 95 has a roller cam. It's just a tad less cam than the HO 5.0's cam with. Here are the specs for the F4TE (your cam) .422/.445 lift, 256/266* advertised duration. The HO cam is .445/.445 lift, 276/266 duration (some list it as 276/276) No ZDDP needed
Old 04-27-2013, 08:21 PM
kermmydog's Avatar
Thumbs up
Thanks for the info.
Craig
Ford 302 8086ford Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 11-04-2016 10:40 PM
what year 302 do I have 1990-f250 1987 - 1996 F150 & Larger F-Series Trucks 6 07-20-2014 10:18 AM
289/302 Crank Pulley Question GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 04-30-2010 07:25 AM
Roller cam in 302-What years? Brett1989 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 09-13-2008 07:11 PM
Last year of 302 for explorer Ranger GT2 Explorer, Sport Trac, Mountaineer & Aviator 4 07-09-2008 11:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
