79 Wiring Schematics - Ford Truck Enthusiasts Forums
Old 04-21-2013, 05:33 PM
ranger429 ranger429 is offline
ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.
This may apply to earlier years but it is specific to 79. Eventually I'll get the whole book into this thread. If you need to see bigger pictures of the color/number follow this link: 1979 Ford Bronco Wiring diagrams pictures, videos, and sounds | SuperMotors.net
Fuse panel.
Ignition Switch C-412.
Headlight Switch C-701.
Instrument Cluster with Gauges C-208A.
Instrument Cluster without Gauges C-208.
Voltage Regulator C-204.
Alternator C-209.
Control Module C-321.
Distibutor C-322.
Fender Apron Plug C-306.
TurnSignal Switch C-305.
Turn Signal Switch Connector C-713.
Brake Light Switch C-802.
Emergency Flasher C-805.
Turn Signal Flasher C-806.
Old 04-21-2013, 07:31 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Reps sent
Old 04-22-2013, 07:30 AM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
Having the circuits listed in a number sequence is pretty convenient! Thanks for posting up
My 79 crewcab build thread (56K pics inside) ranger429 1973 - 1979 F-100 & Larger F-Series Trucks 236 01-01-2016 06:50 AM
Finally finished my Pwertrane rebuild jowens1126 1978 - 1996 Big Bronco 9 02-04-2015 10:04 AM
New Project. 79F250 JFlom77 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-29-2014 10:13 AM
My 79 4x4 build. hav24wheel 1968-2013 Full Size Vans 47 11-07-2012 08:56 PM
Bronco gets a new floor pan. AbandonedBronco 1978 - 1996 Big Bronco 8 11-14-2011 08:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
