best engine stand article
on
finally got around to adding the pics of the engine on the stand...
here if you're interested THE BEST DAMN ENGINE STAND
and here if you ain't ... wish I could do a video just to show you how easy it really is.... technology eludes me and my phone
john
john
on
my chore this afternoon is to find a part for a 30 year old Yazoo big wheel commercial mower that I've been piecing together for the last 20.. I used my last spare part of a parts mower last iime.. It's the jack shaft assembly that drives the wheels and I need that part !!!
later
john
on
no Ross... sadly no lathe or the knowledge to use one... could have learned 30 years ago and didn't have time...
Actually I need the housing for the jackshaft.. the shaft is in pretty good shape. on a 30 year old Yazoo big wheel mower
I"m sitting here studying this one and wonder if I couldn't fab something up using steel pipe bored to fit bearing o.d. and plate to make the saddle and base...... this might be my best option cause the parts are impossible to find unless you find someone with an old deck behind the barn... that's where I'm looking now
j
j
That would be relatively easy to replicate using a pillow block bearing, if the shaft is a standard size. Orientation is 90-degrees to the typical pillow block, tho.
Pillow Block Bearing Heavy Duty Pillow Block Bearings Roller Chain Sprocket
Chicago Fire Patrol
07-27-2008 05:54 PM
54-4U2C
05-15-2007 12:17 PM
