Ordering the correct HPOP?
OK, getting ready to tear down the top of Monster's 6.0l again and would like to make sure that I purchase the correct parts.
My plan is to replace the HPOP, convert to a 2005 intake manifold, add a CCV mod, "redo" the custom air filter (this is not a debatable item), and other "stuff" I might see needing fixed/updated/modded as I am working on her.
Here's my dilemma...while I know the majority of the items I need to purchase, I'm not so sure on the HPOP. I'd like to have the HPOP already in hand before I tear down the engine. However, I've found there's about a 1000 different posts about how to tell if you need to purchase a "3C3Z-9A543-AARM" vs the "4C3Z-9A543-AARM".
My original FICM is long gone and the sticker on the driver's side valve cover only lists the HP and Torque ratings...no year code. The ICP is on the HPOP behind the turbo so I'm assuming that the engine is an early 2003...is there anyway for me to confirm this?
Finally a simple answer...I'm sure this answer is located somewhere within FTE, but I couldn't find it!
THANKS A TON!
Now for a second question...anyone have comments about retrofitting my engine with the 4c3z ICP on the Passenger's side cover? What's needed and how long will it take?
THANKS A TON!
THANKS A TON!
THANKS A TON!
Valve covers.......rocker boxes.....HPOP(?)...stand pipe.......what else, access to the backing plate? I think it's quite a project but have read of a few guys that have done it
Here is a post I've referred to often. On this exact subject:
6.0 Model Year differences
07-15-2012, 11:42 AM
m-chan68
Okay, it seems that everyone is a little confused with regards to what HPOP is used with which model year engine, so I will do my best to clear things up. First, let's start of with the 2003 engine. This will be the model year engine that uses the early aluminum swash plate style HPOP, the earlier of the two IPR valves available for this engine (3C3Z-9C968-AA/CM-5054). The part number from Ford for the HPOP for this engine is 3C3Z-9A543-AARM.
Now onto the LATE-2004 engines. This is the model year that many changes were made, including the piston dome size (rendering glow plugs non-interchangeable between early and late engines), the switch to the wavy rails and the location of the ICP sensor that all of you are well aware of. However, this particular model year of engine still retained the use of the swash plate style HPOP with a different part number 4C3Z-9A543-AARM. If you were to place this pump side by side with an '03 model year engine pump, they would appear identical. And to be honest with you, I couldn't tell what the internal differences between the two pumps are, other than the information found on page #29 of this document:
DTS Articles - Coffee Table Books
The reason being, at the dealership level, we simply replace the pumps when there are issues with them. We don't disassemble them. And, if it matters, this particular model year engine uses the earlier IPR valve (3C3Z-9C968-AA/CM-5054), but uses the later model year injectors.
Now onto the 2005 and up engines. This is the style that originally used the dreaded STC fitting that everyone likes to change up to the one-piece updated branch tube connector (that were installed on 2008 and newer E-Series application engines from new). Not sure what else to say about this version of pump, other than the fact that it is a V-4 cast iron pump that has been far less problematic overall than the '03/'04 style pumps. And lastly, the part number for this pump is 5C3Z-9A543-C, and uses the later model year IPR valve (5C3Z-9C968-CA/CM-5126).
The only other thing I can think of that's worthy of mention is for '03/'04 owners thinking of switching to the '05 and newer style pumps, don't even think about it. For an '03 the later branch tube will not work with the '03 thread in style standpipes. And for you late '04 owners, changing out a branch tube is far more work than it's worth, just to put in a '05 style pump.
HOPEFULLY this clears things up.
Here's a link to the thread, more good info:
https://www.ford-trucks.com/forums/1...firmation.html
m-chan68
I should have a video tonight of a truck we updated (actually are updating now,, the cab is still up). 03's just take more parts but can be done. I personally like the way the late model pumps fire up. Most 03's kinda roll to a start,, 04's tend to fire better,, but 05 n up,,, fire right up. Jmho.
Here is the video I shot tonight
I should've shot it after doing the ccv. I sacrificed one of my stock exhaust to use the stock downpipe and the flange just before the cat,, then used his 4" exhaust past the downpipe. aftermarket exhaust really only fits well when installed cab off. Those stupid clamps always hit the pinch weld or the Trans tube,, and very few actually have the bend right on the downpipe. This trucks exhaust and ccv are beautiful now.
Caleb's final video. - YouTube
Also, anyone have any suggestions on which HPOP to put in? I simply do not have the budget for the Dieselsite Adrenaline.
That leaves you with a Ford reman and after reading everything about them, keep your fingers crossed you get a good one the first time!
In case you haven't read yet, most have to try 2 or 3 different pumps until they get a good one and then fight Ford over it. Seriously, save yourself the headache and do it once.
Were you talking about one of these Terminator Engineering High Pressure Oil Pump T500 for 03-04 6.0L PowerStroke units? I know nothing about them, but for less than half of the cost of the Dieselsite unit, I'm curious about peoples opinion of them.
Hint............there is a reason that pump is even less than a reman Ford, and half of the good one. If I do another early build HPOP it will be the best one there is, the Adrenaline.
I'm not saying this is a bad choice but when the website tells me I should have no problem getting 3000 psi, they are setting the bar a little low with a system that is capable of 4000+
