Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van SPONSORED BY:
Fuel Injector Top O-Rings/Seals ~ The Whole Story
Old 04-21-2013, 12:48 AM
creator creator is offline
creator has a good reputation on FTE.creator has a good reputation on FTE.creator has a good reputation on FTE.
This is a Write-Up on the Top Fuel Injector Seals & The Nipple Cup O-Rings in the High Pressure Oil Rail
If you find a leak at one of your top injector seals you probably have a leaky nipple cup also... Don't learn the hard way like I did
~How to Diagnose and Replace~
Fact 1:
The top injector O-Rings can be easily replaced. You do not have to replace the whole injector as Ford would do.
Fact 2:
There are O-Rings behind the the Ball Tubes/Nipple Cups in the High Pressure Oil Rail. They are serviceable and easily replaced with the proper tool. YOU DO NOT HAVE TO REPLACE THE ENTIRE OIL RAIL AS FORD WOULD FOR $500 a PIECE!
Fact 3:
A Leak that shows up in your top injector O-Ring is probably actually originating above at the nipple cup seal. The high pressure oil actually follows the body of the nipple cup and attacks the top of the top injector O-Ring. This can be easily diagnosed by inspecting your old top injector O-Ring, if the top looks eroded, but the bottom looks fine, you have a leak at the nipple cup.
Diagnosis and Repair
Parts Required:
  1. O-Ring kits that include the top injector seal and a new retaining "C-Clip"
    There are 2 major manufacturers that produce these;
    (I actually ordered mine from InjectorWhse.com for $4.29/ea under the part # AP0002 they sent me the Bostech kits)
  2. Nipple Cup / Ball Tube Removal Tool
    I believe Bostech is the only one making these(I found others re-branding it);
  3. Replacement Nipple Cup and O-Ring Kit
    Bostech is also the only ones making these also;
    (I chose to replace all 8. Each kit includes a brand new nipple cup and they retail for $39 each, but you can replace all 8 and buy the tool for less than a new oil rail)
Step 1:
Determine that you actually have a high pressure oil leak. This has been covered quite a bit, but I do have a video on this below.
It should be noted that many people are driving around with small HPO leaks that don't keep them from starting or running. The only way to really find all of the leaks in your HPO system is to test with a higher pressure source such as a Nitrogen bottle instead of shop air. Your HPO system runs at 3500+ PSI under WOT, so 100PSI is nothing and will only show you major leaks. A Nitrogen bottle will get you to around 1000 PSI. Lucky for us shop air will find the leaks big enough to keep up from starting and running. Leaks at the nipple cup seal actually can't be heard with shop air, Believe me I went though this 3 separate times for failed Top injector seals and never heard a leak once I replaced the Top seals, only to have the same seals fail weeks later. This is why I'm writing this post, so that others can easily diagnose a bad nipple cup seal.
This is an old video I did, but It's pretty accurate.
Step 2:
Determine that your leak is at one of your top injectors. You will feel/hear air coming out around the top of the injector under the oil rail. I made a video of one of my leaks, but an air leak is hard to catch on video
Step 3:
Replace your top injector O-Ring or Seal. The best way to explain this is in a video. Once you get the hang of it, it is actually quite easy. I have done it with the injector still in the engine, but I DON'T RECOMMEND THIS It is much more difficult, frustrating and time consuming trying to get the retaining clip out lying on top of the engine. I think the rear injectors would be near impossible. You already have the o-ring kit, just pull the injector out.
Step 4:
Examine your O-ring. If it looks like it is eroded from the top(nipple cup side) Down, you need to replace your nipple cup seal also. The bottom will have a nice smooth, flat, undamaged surface where as the top looks sand blasted. You may even find little bits of rubber o-ring all around the retaining clip and metal beveled keeper ring.
Step 5:
Replace one or all of your Nipple Cup Seals. If one is bad, the others may be failing also. Give your nipples a wiggle, if they feel loose at all, replace them. You don't want to get stuck somewhere you can't fix it. You should feel a snugness and resistance as you wiggle the nipples. The ball of the cup seals against and o-ring, so if it doesn't feel like it's contacting rubber you probably have at least a small leak.
The Tool Used to Remove the Nipple Cup and Replace the Seal:
The Repair kit Comes with a Brand New Nipple Cup and an Upgraded Viton O-Ring
Step 6:
Put it all back together. If you have never had your oil rails off before there are a couple things to note;
1: It takes quite a bit of cranking to purge the air out of the HPO system once re-assembled. I like to unplug the FICM relay and use the Ignition pigtail to the positive battery terminal if I didn't pull any injectors.
2: If you had one or more injectors out, you need to re-prime the fuel system and purge any air BEFORE the FICM tries to fire the injectors. In this case I use the key to prime both the HPO and Fuel System. I unplug the Glow plug relay connectors then just cycle the key on and off cranking for about 20 seconds a time. Cycling the key ON/OFF is the important part here! This Turns the Fuel Pump On and Off to purge the air By the time the Oil Rail has purged enough air out to develop the 600PSI needed to tell the FICM to fire the injectors, you will have turned the fuel pump on and off at least 5 times and enough to purge the air out of the fuel lines.
Step 7:
If you just replaced all of your nipple cups & O-rings and All of your injector O-rings, have yourself a beer and rest assured that your HPO system is solid and won't develop leaks for a long time....
My Story (Why I had to do this):
I had a high pressure oil leak at one of my top injector O-Rings so I replaced it. When I replaced my head gaskets a few weeks later I decided to go ahead and replace the rest of them while I had all of the injectors out. I drive long hard miles for my work generally towing something, Within 10,000 miles the same O-ring that had failed before failed again (catastrophically; the beveled keeper ring had shattered into a few pieces and the O-Ring was in 2 pieces that I could find). I replaced it thinking it was a fluke or something. Then within 2 weeks of heavy driving I had 2 more develop leaks bad enough that I had a Hot no start situation. (Luckily I had shut it off in a Walmart parking lot and was able to go in and buy their mid sized air compressor and the biggest inverter they had to air test my HPO system right there in the parking lot). I had developed leaks at 2 more injectors on that same rail side. I fixed them right there in the parking lot(1500mi from home). I was pissed, naturally, and sent a long email to the company I ordered the O-rings from thinking they were inferior. They forwarded my email straight to Bostech and within 24hrs the general manager replied via email. His name is Brian and he is actually a very nice, very knowledgeable on the 6.0L engine. He sent me all kinds of information and pictures(some of which I have included above) and we even ended up talking on the phone for almost an hour about the nipple cup seals, and all of the other known problems on the 6.0L. I didn't even know there were O-Rings in the oil rail and based on the limited information I see on it in the forums not too many people do either, hence this write-up.
Here is what a catastrophically failed O-Ring looks like. The O-ring was in at least 2 pieces, the keeper ring was shattered into at least 2 pieces and the C-clip was all bent and deformed:
Old 04-21-2013, 12:54 AM
I tried to keep this clean and concise for future reference. It actually took me a long time to put this together. I'm happy to edit the first post with any corrections or info to make this more clear for future readers, just let me know.
~Corey
Old 04-21-2013, 01:23 AM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a brilliant futureBLADE35 has a brilliant futureBLADE35 has a brilliant futureBLADE35 has a brilliant futureBLADE35 has a brilliant futureBLADE35 has a brilliant futureBLADE35 has a brilliant futureBLADE35 has a brilliant futureBLADE35 has a brilliant futureBLADE35 has a brilliant futureBLADE35 has a brilliant future
Great writeup Reps given
We need this one in the Tech Folder I havent seen anything like it in there
That Took alot of work to do this writeup Alone I know its very time consuming to get that anmount of info on here
The Only thing I would add and maybe I missed it But you can run with valve covers offf to check for leaks too However its alot of work to hook all stuff back up to get to a runable condition and Tie stuff like the Ficm and GPCM Back out the way
But Great Job!!!
__________________
Benny oem hpop 1/8/14,update ipr screen
2003 6.0, 4X4 srw, short box, born on 3/28/03 Moog ball joints,DC POWER 190A ALT Duralast Goldtop batterys 10/7/2012,RECON LED SMOKE MIRROR LENS,4 inch turbo back magnaflo exhaust,no kitty, 6 in. lift, BFG 315/75r16, python remote start alarm,pioneer system2 12''subs 1600watt amps ,scangaugeII,coolant filter, blue fuel pres spring, Fresh oil cooler 6/1/11 Final Charge Cat EC-1 rated Silicate Free ELC coolant, Sinister Full egr deleate, ROTELLA T-6 5w-40syn,updatedHPO screen,updated oil filter stand pipe, TC SX8000
Old 04-21-2013, 01:29 AM
04badford 04badford is offline
04badford has much to be proud of04badford has much to be proud of04badford has much to be proud of04badford has much to be proud of04badford has much to be proud of04badford has much to be proud of04badford has much to be proud of04badford has much to be proud of
Thank you Creator for showing , reps sent , high mileage trucks and or pulling should be aware of this problem. what would be some other,running Issuies to point to this?I went thru all vids very Interesting
Old 04-21-2013, 01:46 AM
But Great Job!!!
Thanks!
I actually have a newer video I did with the valve covers off, but it was done after the leaks were fixed so there is no dramatic leak effect. If there is enough interest I'll add it in there.
Old 04-21-2013, 03:18 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
For pressure source please stick with Nitrogen or Argon gas not Oxygen.
Oxygen does not do well at any pressure with oil.
Oil and grease are particularly hazardous in the presence of oxygen
as they can ignite spontaneously and burn with explosive violence
They should never be used to lubricate oxygen or enriched-air equipment.
Special lubricants which are compatible with oxygen must be used under
certain conditions
Other that that I think this is a very good write-up. I just don't want to have to send Emails
to the moon is things go bad.
Sean
__________________
Three Happy Cats "How do you eat an elephant? One bite at a time!"
Mods Blue Spring, High Idle(BCP), Coolant Filter,SCT from http://www.gearheadautomotiveperformance.com/
HFCM Drain Plug, Nav System, Leveling Kit, Backup Camera, HID Fog 3000K & Driving Lights 4300K
6.0l Forum Map : Ask me About It
Old 04-21-2013, 03:25 AM
certain conditions
Sean
Thanks for catching that Sean!
I edited the first post to exclude testing the HPO system with O2.
That's the great thing about forums. More minds are better than 1 (or none o_O)
Old 04-21-2013, 03:53 AM
Yahiko's Avatar
I have hears to some very scary storied about O2 and oils. I think one
of the worst is a LOX leak and having a vehicle tire run over it on
pavement that has some grease. If you lucky you get a POP if not you may
see flying tire. Or so the story goes. I just know what they teach in the section
on handling compressed gasses. Also with a high pressure tank you can have a
regulator fail and get more than you bargained for. I know of one dead and one badly
injured flight-line mechanics that found that out on a nose gear. 9,000 PSI from
the bottle blew the tire into little parts and shredded the wheel.
The lesson is always check the regulators and start at low pressure. ALWAYS!
Sean
__________________
Old 04-21-2013, 06:52 AM
MC5C MC5C is offline
MC5C has a very good reputation on FTE.MC5C has a very good reputation on FTE.MC5C has a very good reputation on FTE.
Great write-up, really professionally done. Completely explains the issue and the solution.
Brian
__________________
2005 F250 XLT Supercab 4WD Shortbox, stock as possible, "Blue Spring", Scangauge II, Autometer fuel pressure and voltmeter, Bilstein HD shocks and steering damper. Rotomaster turbo
Old 04-21-2013, 07:24 AM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
I added this to the Tech Folder, very nice
__________________
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=209298&.jpg
John
Read First FTE Guidelines ULSD Click Here
2003 F-350 Reg Cab 6.0L
Old 04-21-2013, 12:32 PM
retiredinstructor retiredinstructor is offline
retiredinstructor is gaining momentum as a positive member of FTE.
Thanx creator very well done reps given
Old 04-21-2013, 08:56 PM
Piolet's Avatar
Piolet Piolet is offline
Piolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to beholdPiolet is a splendid one to behold
Great job. Reps sent. Thank you for taking the time to put that all together and share what you learned.
__________________
Colm
2003 SuperDuty 6.0L 4x4 CC SB - 338,000 miles - Rolled off the line 02/20/2003 - 17mpg
1997 Explorer 4.0L 4x4 6V OHV - 172,000 miles
Due to recent budget cuts the light at the end of the tunnel will be turned off until further notice.
Old 04-21-2013, 09:05 PM
Thanks Everyone!
Just trying to give back.
Old 04-22-2013, 09:28 AM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
Reps sent from me as well. Very well written!!
__________________
Scotty
06 F-250 Lariat C.C too many mods to list
07 F-350 Lariat C.C DRW 4x4 - ARP studs, ADP custom built stage 2 fuel system, 5" TBE, custom ADP f650 dash, SCT with custom tunes, more to come come Join the Texas Chapter Click Here!!
Old 04-22-2013, 12:10 PM
CPB1's Avatar
CPB1 CPB1 is offline
CPB1 has a great reputation on FTE.CPB1 has a great reputation on FTE.CPB1 has a great reputation on FTE.CPB1 has a great reputation on FTE.CPB1 has a great reputation on FTE.CPB1 has a great reputation on FTE.
Wow, nice job. Thanks for sharing that . This is the first I have herd of this, good to know.
__________________
Chuck
2005 F250 ccsb
Similar Threads
It Runs.... The Blackwater Engine Fixed Right at SuperDutyService creator 6.0L Power Stroke Diesel 18 04-24-2014 08:39 PM
Glow Plug Part #s 2003 VS 2004+ creator 6.0L Power Stroke Diesel 5 04-19-2014 06:02 PM
Blackwater Engines - Is .032" Piston Over Block Normal? creator 6.0L Power Stroke Diesel 14 12-05-2013 07:11 PM
Delco Remy ~LVD~ Low Voltage Disconnect Wiring? creator 6.0L Power Stroke Diesel 0 07-17-2013 06:59 PM
Blackwater Engines - Re-Use of valves from Broken Injector Tip Engine? creator 6.0L Power Stroke Diesel 16 04-10-2013 07:21 PM
Tags
6.0l, ball, cup, ford, fuel injector, nipple, o-ring, powerstroke, seal, top, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
