UPDATED Fuel Injector Top O-Rings/Seals ~ The Whole Story
#91
That's about the only explanation since other injectors Was Clean
Use your judgement on Pulling Banjoes Off it might not need it
If you did pull banjo and blow just do the 1 side that had the bad inject and it maynot need that IDK
#93
i highly doubt the copper burned away. look up the combustion temp of copper, it would leave very obvious traces. temps that hot there would be serious erosion\jetting on the injector surface and the bore in the head. No way it would all burn up 100%. It fell off during install or got foregotten on 1 hole. Nobody is perfect.
Well maybe me :-) J/K
#94
The Copper washer gets Burned up from Overfuel condition from what I understand Seen more then 1/2dozen that was missing the washer on here
If copper washer would been Missed IDK ifthe Injector wouldn't have run for almost 1 year I think it would have Burned up the Orings fast
maybe the washer is still in the Inject cup IDK
#95
#96
I see that (Copper melting Point Temp) Inside the cylinder being Achieved Very easy with an Overfuel condition from injector Dumping Fuel in
Iv seen guys on here get to 1500+ at there EGT Sensor so inside the Cylinders themselves it gets Way Hotter
IMO if Copper washer is Not in the Inject cup THEN it Burned up
All the Evidence is covered in SOOT
1,984°F (1,085°C)
Copper, Melting point
<table class="infobox bordered" style="width: 22em; text-align: left;" border="1" cellspacing="0" cellpadding="2"><tbody><tr><th>http://en.wikipedia.org/wiki/Melting_point</th><td>1357.77 http://en.wikipedia.org/wiki/Kelvin, 1084.62 °C, 1984.32 °F</td></tr></tbody></table>---------------------
Over fuel will also Burn a Hole into the Piston
1,984°F (1,085°C)
#97
melted copper is still copper it had to go somewhere. copper burning will be much hicher, but either way temps that high the injector is going to show signs of it. For sure temps that high are not impossible. as far as his sig indicates, I'm assuming stock injectors and a tune more or less. unless his tune is totally stupid his temps shouldn't be stratospheric
#98
#99
#101
LOL, agreed but it still doesn't change the fact that it ran fine for almost a year, the stuff is below the fuel section on the injectors could only have gotten in there during install and most likely kept the injector from seating completely and torquing correctly thus melting the Cu washer over time.
Thank God it didn't hydro lock, just ran rough on inclines and NEVER threw a CEL code.
D
D
#102
Right it took time for the injector Plunger to Fail and overfuel to burn the washer
YOU Need more then the BLUE SPRING!!!! MAYBE the RAG caused Fuel STarvation to that inject
You need aRegulated Fuel return for your Injectos and TUNES tat Injector Died from FUEL STARVATION most likely and Killed the pluger and then Leaked out the Pintal causing Overfuel
That's ^^common way to fail (As long as a Rag isn't part the Install LOL)
Now the Kicker is the Rag and how much it played
I don't think the RAG caused any Seal Issue since it ran a Year
It may have Starved the inject for fuel though
#103
Is that Screen on the Far side of the Pic have Bits of RAG in it??? It just looks like it did????????????????????????????
But hard to tell
Those screens let the fuel in the inject
But hard to tell
Well I had #5 at - 49 Contribution so i went and got it, look at what I found!!!
Still stumped as to how this happened and the copper washer was gone. Just put these in this January !!
<a href="http://s449.photobucket.com/user/Dlinzy993/media/IMAG0674_zpse035219d.jpg.html" target="_blank"><img src="http://i449.photobucket.com/albums/qq212/Dlinzy993/IMAG0674_zpse035219d.jpg" border="0" alt=" photo IMAG0674_zpse035219d.jpg"/></a>
Thoughts?
D
Thoughts?
D
#104
If this was done at a SHop WHEN these injectors went in Thenit really Looks like Sabatoge to me
Maybe it got missed but I doubt it
The shop was going to blame inject especialy if the rag was in that screen on 1 side they new it would take time to fail
If you installed them (Or a Friend) then of coarse it got missed you wouldn't do that intentional
#105
Good News... I think.... I found the Cu Washer in the bottom of the injector cup. It was soot covered but still it's original size and shape. This was #5 so I had to use a mirror and flashlight to see it.
A 20+ yr. Ford Tech performed the work at FORD Dealer, but died a few days later HT so I can't kill him... lol
The thread could've got in the holes from wipiing it off and carrying it around to get pictures. It was all originally under the bottom o-ring in a tight constriction circling the injector as if it was twisted on it purposely.
Denny
Denny
