Rebuilding my 1950 F-2
on
The problem with the 1997-2003 F-150 2WD suspension is:
1. The front track width is wider. 65.4" vs stock 58"
2. You would have to graft in the entire front frame section and it is also too wide. 39.5" vs stock front width of 32" (rear 34").
3. Metric wheel bolt pattern 5 x 135mm. This bolt pattern was only used 1997-2003 vs stock 8 x 6.5" 1948-present day or 5 x 5.5" 1940's-present day
4. Shouldn't be attempted unless your a well experienced fabricator.
It will be much easier and surprisingly cheaper to fix the stock suspension plus you will have it road worthy faster. It should be relatively easy to find a running 302/351W and you won't have deal with making it fit as its already equipped. The fuel injected engines just need an intake and distributor change to be carbureted.
Scott2k
12-02-2018 04:33 PM
mike85120
04-28-2014 04:09 PM
Dano78
06-01-2011 11:09 PM
lvin4jc
20
06-22-2010 08:27 PM
