Anybody out there got any good patch pieces? I need probably about 24" to 30" in length. It doesn't need to be continuous. Each piece probably about 4" long to patch where the bolts go in.
Chris my message box was full so some messages got rejected, but I posted a pic of my parts truck on my build thread check out the boards and see if they will work for you as I don't know which side of them you need, you'll see in the pic that on the 1 ton trucks they only cover the cab, so hopefully you need the front part. you can graft them together, a little body work at the seam, and then shoot them with non-slip bedliner coating.
sorry too hijacked,but if them running boards are rust free i would be really interested. my 42 2ton running boards are rusted an wore out but maybe pieces could be used.i can take a picture tommorrow.if i can find better ones i would give them away.
you can here it running,on you tube! my first and only video,so far!! don,t know how too link. try (1942 ford truck first start 40 years 001)you will see i had green tape on the wiring
