58 f350 axle???
Old 04-20-2013, 06:42 PM
CollinF's Avatar
CollinF
CollinF is offline
58 f350 axle???
Looking into picking up a 58 f350, Noticed this axle I have never seen before. Kinda looks like a 9" but full float, 6 bolt hole pattern and rectangle type tubes... what is it? I've been searching and I THINK its an timken or eaton
EDIT: SRW and 6cyl with manual
Old 04-20-2013, 08:41 PM
spurredon's Avatar
spurredon
spurredon is offline
Timkens had a Id. tag and the back side of them while Eatons were only marked on the carrier with stamped numbers.
By the way, BUY IT!
Old 04-21-2013, 12:10 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
I have a spare axle if you want it! 16, 17 or 17.5" wheels? F350 stakebed or pickup. Inquiring f350 minds want to know. And like Spurredon says. Get out there and buy it. What are you waiting for?
Old 04-21-2013, 12:42 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1957/58 F350, only rear axle available: Timken model B100. Available ratios: 5.29-1; 6.20-1; 6.80-1.
All 1953/66 F350's have 6 lug wheels on a 7.25" bolt circle.
Old 04-21-2013, 09:46 PM
CollinF's Avatar
CollinF
CollinF is offline
Thanks guys. I haven't checked into the wheels as of yet. Ole lady has given her opinion aka its ugly and rusty. Still on the fence bout it
Old 04-21-2013, 11:31 PM
GB SISSON's Avatar
GB SISSON
Now tell us something Bad about it....... Here are my F350 fridge trucks. The green one is my '59 resto (rusto)-mod with a cummins 6at. The yellow one is the parts truck I just traded a kerosene lantern and a rusty winchester 22 for. Today I started thinking how hard it would be to part it out. I have the original ford script stakebed from the '59 on it now. All I need is an engine, transmission (and a transfer case and a couple of dana 60s)..........
Old 04-22-2013, 05:24 PM
CollinF's Avatar
CollinF
CollinF is offline
Its not 4wd lol But I would change that
Old 12-18-2022, 09:50 PM
Cprof's Avatar
Cprof
Cprof is offline
4th Gear
58’ F350 axle swap?
I have a 1958 F350, after doing some work I found out it had a b100 timken rear end. It only goes about 43 mph at good rpm’s. I would really like to be able to go about 50-55 in it and I was wondering is there a good axle out there that I could find that would let me drive 50-55 with out winding the engine up tight. It is an absolute survivor and only has about 49,000 miles on it. 233 paired with a 4 speed trans. 5.83 gear ratio.
Old 12-19-2022, 06:39 PM
spurredon's Avatar
spurredon
That is a sharp looking truck. Here is some interesting reading F350 Timken Rear Axle Ring & Pinion - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old 12-20-2022, 08:35 PM
Cprof's Avatar
Cprof
Cprof is offline
4th Gear
Hey thanks for the compliment! I’ll look into that thanks for the link. There is more coming for the 58’ she isn’t done yet, I got some small stuff in the interior to do and cosmetic stuff to do on the outside. Cab lights, bed pinstripes, and maybe a round fuel tank on the bed just for some cool looks!
Old 12-22-2022, 12:30 PM
tripleframe's Avatar
tripleframe
tripleframe is offline
Originally Posted by Cprof
Iis there a good axle out there that I could find that would let me drive 50-55 with out winding the engine up tight.
For the simplest improvement, I would look for a complete Spicer rear end with leafs and hangers out of a '62-'66 F 350 ( all had the same 6 bolt pattern ) Most have 4.88 gears, but will be an improvement over the 5.83. Driveshaft might need to be lengthened or shortened slightly. Newer axles with higher ratios are all 8 lug.
Old 12-23-2022, 10:59 PM
Cprof's Avatar
Cprof
Cprof is offline
4th Gear
Hey thanks for the info I’ll look into that. I know of a couple old 60’s ford trucks I could probably get my hands on. Any other info about the Spicer rear end that I need to know about? Common problems/issues?
Old 12-24-2022, 02:22 PM
tripleframe
The industry standard for many years, no real problems accept for the low gear ratios. Spicer 70's came in higher ratios in the 8 lug, 4.10 and 4.56, but you really don't want to mess around with paying someone to change out the guts on the integral style axle. The Spicer 70 4.88 unit would be the cheapest and easiest upgrade, however, 4.88 is still considered low. 1 ton frames all have the standard 34" rails, so old unit with springs and hangers intact can be removed and Spicer unit with springs and hangers installed. Spicers have a metal ratio tag attached to one of the rear cover plate bolts. IF no ratio tag, you should do a decode on the warranty plate attached to door or glove box. A super rare 4.10 ratio with the 6 lug system was a new option on the '66 F 350, a one year only deal. IF you found one of these, you hit the jackpot!.
Old 12-26-2022, 10:22 PM
Cprof's Avatar
Cprof
Cprof is offline
4th Gear
Ok, thank for all your help, I know off a couple trucks In my area that are mid 60s ford 1tons and a least one would most likely have 4.88 gears if not I’ll keep on looking!
whodat_ford
1999 to 2016 Super Duty
05-03-2015 02:59 PM
fordf350camper
11-27-2012 10:25 AM
F250racer
04-21-2012 01:59 PM
Guiny
05-03-2011 04:22 AM
treefort
08-16-2001 04:16 AM
Quick Reply: 58 f350 axle???
