F250 with 12V cummins conversion - Ford Truck Enthusiasts Forums
Vehicles for Sale All vehicles (Ford Truck or otherwise) for sale here
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Location (State):
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State):
Item Condition:
Old 04-20-2013, 05:44 PM
carcrafter22's Avatar
carcrafter22 carcrafter22 is offline
carcrafter22 is gaining momentum as a positive member of FTE.carcrafter22 is gaining momentum as a positive member of FTE.
Year: 1996
Make: Ford
Model: F-250
Price: $10000
Mileage: 93000
Color: white
Private or Dealer Listing: Private Listing
Location (State): TX
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Color: Gray
Engine: 5.9 12V CUMMINS
Hi guys, I'm selling my dads 96 F250 2wd extended cab long bed 96 12V cummins for him.
The truck is in excellent condition, the body is very straight and paint is an 8 out of 10, interior is 9.5 out of 10. Paint is white, interior is light grey. The body has 92,XXX miles on it, engine has 120,XXX on it, transmission has 40,XXX on it.
List of modifications
96 5.9L 12V cummins engine. Has leaks, have to fix the lifter cover gasket this week sometime. Engine runs very good and pulls very strong.
KDP was taken care of while engine was out
New core support
New 7.3 powerstroke radiator bought from ford
New transmission cooler for a 2005 F250 diesel (this thing is huge and works great to keep the tranny cool, bought from ford)
New a/c compressor, lines, dryer, cleaned the original condenser
New alternator
New power steering pump
Resealed vacuum pump
Intercooler from a 2006 dodge diesel
custom 3" intercooler piping ceramic coated and tripple ply boots at all connections with T bolt clamps to hold them in place
HE351 turbo with 24,000 miles on it ceramic coated to match the valve
covers and intercooler piping
Custom mandrel bent 4" exhaust
New lift pump
New shutdown solenoid for injection pump
DDP 75hp injectors (roughly 1,500 miles on them)
Injection pump has been checked out and in great shape, also had the governor springs changed to 4000rpm kit
Electric fans with aluminum shroud.
shortened driveshaft (done at fort worth gear and axle.)
PCS transmission controller
Destroked motor mounts
Destroked billet adapter plate and flywheel
Precision billet tripple disk converter
HD Rebuilt E4OD transmission has good clutches and steels, nothing fancy but it shifts well.
XD Diesel wheels 17" with michelin tires (tires are roughly 30-40% left)
Electric tank selector for switching between the two tanks, changed out fuel tank sending units to diesel (no fuel pump cages on them)
Dakota Digital 3 in one gauges X 2 one gauge monitors Boost, EGT, Trans temp, The second gauge monitors engine temp, oil pressure
Replaced the factory gauge cluster face (face only so miles are correct on odometer!!) so it has the diesel only lettering and diesel tach.
2 New 1000cca batteries 9/1/12
1/0 custom battery cables replaced all the originals
New PA Performance starter
New Kenwood radio
New Infinity speakers
The entire cab has been lined with 2 layers of dynomat sound deadener to make it much quieter
The hood and firewall are covered with dynomat hood liner
Cruise control does work
Has new front coil springs and alignment just done april 1, 2013
Price is $10,000. Might trade for a classic chevy or ford truck, let me know what you have.
Old 04-26-2013, 09:48 PM
bump bump bump
Old 05-02-2013, 10:08 PM
bump for the day
Old 06-11-2013, 02:26 PM
Just installed a new billet aluminum tappet cover, no more oil leaking down the side of the block. Truck is in great shape and runs like a top.
Old 06-28-2013, 06:21 PM
bump. bump. bump.
Old 07-11-2013, 08:43 PM
bump, bump, bump.
Old 07-18-2013, 08:37 PM
kenvb's Avatar
kenvb kenvb is offline
kenvb is starting off with a positive reputation.
if you werent so far away, would come see it,
Old 07-24-2013, 05:37 PM
flainn's Avatar
flainn flainn is offline
flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.
What's with the filters on each valve cover?
Old 08-02-2013, 11:43 AM
Anyone want to trade for something cool?
Old 08-02-2013, 11:59 AM
El Camino Man El Camino Man is offline
El Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to behold
Just asking: What years of classic chevys are you wanting?
Old 08-02-2013, 12:44 PM
1949-1965 would be great but I'm also open to other vehicles or cool man toys.
Old 08-04-2013, 06:00 PM
Price dropped to $8250, just had inspection renewed 8/1/13 passed with flying colors.
Old 08-04-2013, 08:03 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
if you were half way close to md that truck would be having md plates!
Old 08-04-2013, 08:08 PM
Plane tickets are cheap. I promise you won't be disappointed.
Old 08-05-2013, 09:55 AM
Bump for a great price on a great truck! And your inbox is full CarCrafter lol
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
(Build Thread) My 1995 F150 Flareside Ext. Cab NiftytheF150 1987 - 1996 F150 & Larger F-Series Trucks 10 11-22-2014 01:50 PM
1987 Ford F-250 99xjon 1987 - 1996 F150 & Larger F-Series Trucks 29 08-18-2014 10:31 AM
Air pump question spyder0382 1987 - 1996 F150 & Larger F-Series Trucks 2 07-07-2014 05:09 PM
Custom Auido Sound System F250 xalaskan Ford Truck Parts for Sale 0 04-27-2014 05:08 PM
1990 ford f150 build thread stirling35 1987 - 1996 F150 & Larger F-Series Trucks 18 02-16-2014 06:28 PM
