1969 4 wheel Power Drum to front disc
I have read so many different things on conversion. I have a 1969 f-100 2WD with 4 wheel disc brakes. I want front disc. I have access to a full front end of a 2wd 1979 f100. Can I just grab caliper mounting bracket or would I need spindles etc..... Thank you for your time.
I have read so many different things on conversion. I have a 1969 f-100 2WD with 4 wheel DRUM brakes. I want front disc. I have access to a full front end of a 2wd 1979 f100. Can I just grab caliper mounting bracket or would I need spindles etc..... Thank you for your time.
Easier to park them side by side and swap parts.
Read Up:
65-72 PS & Disc Brake Swap
Classic Trucks Magazine F100 Power Disc Upgrade
I was told steering linkage, tie rod ends etc.. and it says the same here.
Installing Disc Brakes on Your 2WD Pickup - Pt. 2 - FORDification.com
Git to work!
Gouge Eye
07-12-2012 11:13 PM
TheRooster12
11-22-2010 07:47 PM
mattie333
02-24-2005 11:19 PM
gonefishin
15
11-02-2002 06:11 AM
