gasser to idi - Ford Truck Enthusiasts Forums
gasser to idi
Old 04-19-2013, 08:30 PM
burton7.3 burton7.3 is offline
burton7.3 is starting off with a positive reputation.
gasser to idi
hey guys looking for some info on the swapping from a gasser to idi. On the gasser cross member there is a big hole on the driver side what do have to do with that. do I have to weld a piece of metal in there
Old 04-19-2013, 08:59 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is online now
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
Have to swap intrument cluster and harness after that im not sure, Engine crossmember should work.
Old 04-19-2013, 09:04 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
You will need all the wiring for the engine, cab and dash, as well as a diesel specific transmission (a gas tranny will not bolt up to a diesel).
Fuel tanks and fuel system, and diesel front springs for suspension.
That big hole I think is there in all trucks, it's the oil filter hole for the gas V8's.
You'll need the plate that bolts over it from on the IDI engine.
Like so,
As you can, you will need the motor mount it self, and that plate hanging from the mount seen in this picture.
What kind of truck are looking to drop this in? What's in there now? A little more info from your end will help us, help you.
Old 04-19-2013, 09:42 PM
Ok the truck is 92 f250 with a 351 I'm put a dana 60 in it with 97 psd springs I'm get the plates that bolt to the frame and trying to get a diesel dash it longer term project so I plan on build the motor first
87-91 Gasser to Diesel Tach RacinNdrummin 1987 - 1996 F150 & Larger F-Series Trucks 2 09-16-2014 02:11 PM
What is the best engine assembly lube Cowman79 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 12-24-2011 02:39 AM
A little IDI math ? 7DF250 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 29 11-26-2011 02:06 PM
what to do with the gassers? 460429_freak Alternative Fuels, Hybrids & Mileage 6 07-17-2005 03:49 AM
Gassers, how many miles do you have on your SD? Stampede 1999 to 2016 Super Duty 54 02-24-2004 09:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
