239 Flathead for Sale -?Value - Ford Truck Enthusiasts Forums
Old 04-19-2013, 07:11 PM
51F14ME 51F14ME is offline
51F14ME is starting off with a positive reputation.
I have a 51 F1 with a 289. I like my 289 but stumbled onto a 239 for sale and I am questioning the value. 8BA on heads making it a 49-53 & from a car I believe. The intake says 8BA 8RT & B520 (or 8520 or 6520). The block is painted black, heads red and intake silver. Its obviously been repainted & the heads and block have green paint under you can see in chips. Comes w/transmission. Guy who has it took it on trade for fairlane parts for his brother who wanted it and backed out. "Supposedly" it runs but sitting on ground. Has a new altermnator bolted to it but otherwise looks like original parts and carb. All complete. Oil looks light dirty with no water. Engines turns freely.
Being he took it on trade for brother (& I know these guys a little and know his brother was looking for a 239), I believe he was convinced it ran when he took it. (He has 5 66 & earlier vehicles, all 289's. Knows a bit on horsetrading.)
Ohio location
Any help on the value of this package.
51F14ME
Old 04-19-2013, 07:23 PM
harleymsn's Avatar
harleymsn harleymsn is offline
harleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to all
"Sitting on the floor, 'Supposedly it runs'" leaves a big wide gap. The brother wanting one and then backing out, would raise a big red flag to me. As it sits, I wouldn't go over $100 on it. If they get it running, depending on a compression test, it could be worth up to $500. (Even if it starts and runs, doesn't guarantee that it has good compression, nor does it prove that the block is not cracked or otherwise damaged.
Old 04-19-2013, 07:28 PM
Thats what I was afraid of. Looked online and these seem hard to find so I thougt it might be worth more. He's asking 500 but was clear it was up for negotiation.
Old 04-19-2013, 07:33 PM
What value if got running and had reasonable compression?
Old 04-19-2013, 08:18 PM
johnglock45 johnglock45 is offline
johnglock45 is starting off with a positive reputation.
Flathead
I
Ohio location
51F14ME
Is the trans overdrive or not? I would think 4 to 600. would be fair-you also said had alt. so maybe 12 volt====By the way I'm also in ohio
Old 04-19-2013, 09:09 PM
harleymsn's Avatar
Quote:
Originally Posted by johnglock45 View Post
I
The engine does not really know 6V from 12V
Old 04-19-2013, 09:19 PM
You are correct,but if its a alt,the coil maybe 12 volt if someone did a 12v conversion--by the way ,nice truck, I just got a 50 factory stake truck as my next project.I might be interested in the flathead if it is up for grabs-I;m also in Ohio=====sorry didn't mean to highjack his tread
Old 04-20-2013, 09:01 AM
It is definitely for sale. It does have a 12 volt alternator & coil but not mounted real well. Not sure what the transmission is. I have pics if you send an e-mail. Looking into friend of friend who cab set-up to start supposedly.
If I don't buy I will set you up to look at.
khagberg@neo.rr.com
Lexington Ohio (outside Mansfield).
Old 04-21-2013, 06:56 PM
ok-thanks---
Project Old Red II(1948 F1) cobra_4 1948 - 1956 F1, F100 & Larger F-Series Trucks 55 10-30-2016 03:00 PM
1954-55 239 Y Block Rod Bearings 1950FordF1 Ford Truck Parts for Sale 0 09-19-2014 05:19 PM
This is Crazy Cooter!(lots of pictures) MikePacey 1973 - 1979 F-100 & Larger F-Series Trucks 8 08-06-2013 10:24 PM
C8BA needs pistons 49'er 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 06-21-2012 07:20 AM
1961 Mercury Unibody. Looking for any helpfull info dingfangle 1961 - 1963 F100 Unibody 17 01-23-2011 10:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
