almost OT: Wifes 06 Fusion needs a new PCM... - Ford Truck Enthusiasts Forums
Old 04-19-2013, 09:13 AM
Christof13T's Avatar
Christof13T Christof13T is offline
Christof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant future
Hi there guys...
I know this is not exactly the right place to ask but FTE is home... and i dont trust other forums.
Im sure some here have experience with the issues im seeing.
Engine developed a steady miss and CEL abruptly. Codes showed coil circuit E failure and non specific ecm failure. Research points to shorted circuit for #5 on the board. Have changed plug and cop. No fix. I have ae if that helps... but im new with it and focus more on diesel...
My biggest question now is relative to differences between pcm part #'s. Do they need to match up when replacing like they do on my 7.3Powerstroke?
I know that some pcm's are interchangeable on the Powerstroke... if the pcm on the 3.0 v6 system follows suit... where can i find a cross reference ?
Thanks in advance for any insight...
P-0605 MX_Fyrcaptain 1999 - 2003 7.3L Power Stroke Diesel 7 03-24-2012 06:50 PM
PCM test pin locations cruzer17 1999 - 2003 7.3L Power Stroke Diesel 3 06-04-2011 09:57 PM
Engine codes and PCM bigred66 1987 - 1996 F150 & Larger F-Series Trucks 4 09-01-2005 08:40 AM
EEC codes pulled what do I fix?? Fwayz Aerostar 2 04-20-2004 04:47 PM
Bad PCM? keence 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 08-15-2000 07:01 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
