Possible bcm issue
Possible bcm issue
Only seeing 0.8 volt at the driver door closed and 3.4v at the pass door closed when testing the proper wires at the bcm. Issue is keep alive accessory relay staying on for ten minutes after truck is cut off. Radio won't turn off, windows stay alive, there is NO door ajar light with the doors open. I thought mAybe the switch in the door might be faulty so I used wd40 to make sure they were loosened up and working. They seem to change from small voltage to no Voltage as the doors are opened so it seems they are working.
Looking for any and all info to remedy this issue.
ALSO, hoping to get help troubleshooting the evap code 443. Bought a new fuel cap, no help.
2006 xl 4.6 automatic, power locks, windows, mirrors.
